Integrated vs separates
0 Members and 1 Guest are viewing this topic. Read 1502 times.
apoid1
« on: 6 May 2013, 03:11 am »
What is the advantage of purchase 2.5BSST amp & BP17 preamp vs. B135 integrated amp?
  • The Demo is Everything!
    • http://www.bryston.com
Re: Integrated vs separates
« Reply #1 on: 6 May 2013, 11:28 am »
Hi
None really other than flexibility in the future if you want to go with a different preamp or power amp.
james
srb
« Reply #2 on: 6 May 2013, 03:39 pm »
It seems to me that the integrated might have two advantages, one very small and one more substantial:
1.  As is, the integrated has shorter signal paths with no RCA jack/plug/plug/jack connection between preamp and power amp as well as no extra expense for the cables.
2.  The B135 SST² is $1850 less expensive  ($4695 USD compared to $6545 USD for the BP17/2.5B SST²)
Because the The B135 SST² has separable preamp and power amp sections, you still have the flexibility of going with a different preamp or power amp in the future.  If the power amp gets upgraded, you also have a power amp section that could be used for zone amplification, bi-amplification, etc.
