Maintenance of VS Speakers
0 Members and 1 Guest are viewing this topic. Read 1642 times.
johnlee2002
« on: 5 May 2013, 08:36 pm »
Dear Subject Matter Experts,
Read from other sites/magazines that to maintain the sound quality of the speakers, it is a good practice to tighten the screws on the drivers periodically - however none of these sources mentioned exactly how long is that.
My question:  Do we need to do this for VS Speakers?
Please advise  :)
JackD201
Re: Maintenance of VS Speakers
« Reply #1 on: 6 May 2013, 05:55 am »
For VSA models VR-5 and up, the drivers are floated on a proprietary damping clay compound. I would not tighten any of these screws.
For other models a twist to a firm but not tight fit wouldn't do any harm.
johnlee2002
« Reply #2 on: 6 May 2013, 11:59 am »
Hi Jack,
Thanks for the reply.
If the Anni is made in 2010/11 (the one will added thick wall treatment, very heavy model), is it mounted on the damping clay?
JackD201
« Reply #3 on: 6 May 2013, 01:01 pm »
Hi John,
I'm 99% certain that it is :)
johnlee2002
« Reply #4 on: 6 May 2013, 07:55 pm »
Jack, thank you so much :thumb:
JackD201
« Reply #5 on: 7 May 2013, 02:08 am »
Anytime John  :D
What I would do periodically is tighten the lock washers on your bass module spikes and also check the tightness of the MT modules' rubber spikes. Once a year should be okay. :)
