A useful Magnepan Comparison/Specification log
0 Members and 1 Guest are viewing this topic. Read 4816 times.
medium jim
« on: 4 May 2013, 11:33 pm »
Not sure if this has been prior posted, nevertheless, it is useful:
http://www.integracoustics.com/MUG/MUG/articles/speakers.html
Jim
josh358
Re: A useful Magnepan Comparison/Specification log
« Reply #1 on: 5 May 2013, 02:16 am »
It is useful, but use caution -- not all of the information is correct.
medium jim
« Reply #2 on: 5 May 2013, 02:23 am »
Only a guide, but you are correct about there being some errors, for instance the 2.5R's show a sensitivity of 84db, when I called Magnepan I was told that they were 86db in the chamber and around 88db in most normal rooms.
Nevertheless, a good starting point.
Jim
Letitroll98
  • Too loud is just right
« Reply #3 on: 5 May 2013, 03:00 am »
I've seen the chart, but not on AC, a good addition.
Roger Gustavsson
« Reply #4 on: 6 May 2013, 01:19 pm »
Jim
Well, the figures from Magnepan are a bit optimistic. My own MG 3.6 is about 5 dB below my other well documented speakers which give 87 dB for 2.83 V of input. I have made the comparsion in my sweet spot.
Letitroll98
« Reply #5 on: 6 May 2013, 03:39 pm »
I think the measurement is to be taken at 1 meter, unless I'm wrong.
Davey
« Reply #6 on: 6 May 2013, 03:55 pm »
The Magnepan sensitivity figures have been confusing since day one.....and they still are.  It doesn't help that they advertise a 2 watt sensitivity vice a 1 watt number, which is more or less an industry standard.  And all but the biggest models don't have the theoretical -3db/doubling-distance advantage associated with "near-field" SPL drop off.
However, unless you've had your head buried in the sand, you know that Maggie speakers are horribly inefficient.  So, you know that going in and can base a power amplifier decision on that fact.
Dave.
medium jim
« Reply #7 on: 6 May 2013, 04:49 pm »
Dave.
More confusing is that the measurements are in an Anechoic Chamber (an industry standard) and do not replicate real world rooms which usually are more acoustically lively.  Clearly, Dipoles/planars infuse energy into rooms much differently than box speakers and maybe a different reference standard needs to be conceived and implemented to level the playing field.
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=1&ved=0CDAQFjAA&url=http%3A%2F%2Fwww.ece.utah.edu%2Fuploads%2Fresearch%2Fstudent_labs%2FAnechoic%2520Chamber%2520Tutorial.pdf&ei=39-HUa3eEeTbigL4uoDQDw&usg=AFQjCNEz1efX21pF1GgN-VGn6pMKZDb6pg&sig2=GnkeQ_NI7iYPkKxrX3DOsA&bvm=bv.45960087,d.cGE
http://en.wikipedia.org/wiki/Antenna_measurement
Jim
josh358
« Reply #8 on: 7 May 2013, 11:04 pm »
Jim
If you look around online you'll find an SPL calculator that takes into account both the lower room gain of dipoles and the 1/R radiation pattern of tall line sources. (I'd give you the URL but I don't remember where I saw it.)
josh358
« Reply #9 on: 7 May 2013, 11:14 pm »
Dave.
I think the idea is that expressing the sensitivity as a function of voltage rather than power benefits 4 ohm speakers. :-)
medium jim
« Reply #10 on: 9 May 2013, 08:07 pm »
Josh:
That would be really useful.  BTW, I spoke with Wendell today and he said there is no difference between the 2.5 and 2.6 with regard to their sensitivity. This confirms what I suspected.
Jim
