FS - Decware Taboo MK II Headphone/Speaker amp
0 Members and 1 Guest are viewing this topic. Read 2148 times.
rivieraranch
« on: 4 May 2013, 04:51 pm »
BACK ON THE MARKET AGAIN
TABOO MK II - ORIGINAL OWNER
MANUFACTURED SEPTEMBER 2010 - SN #44
BLACK FIGURED BASE & GOLD KNOB
V-CAPS
HAZEN GRID MODIFICATION
HEADPHONE OUTPUT WITH SPEAKER CUTOFF SWITCH
TWO SETS OF VARIABLE INPUTS WITH SWITCH AND ONE FIXED INPUT
This is a well seasoned unit that played in my office for about a year. The VCAPS give the unit a nice sweetness that defeats sibilance.  I sent this back to DECWARE in 2011 for a headphone jack. When it was there I had a speaker cutoff switch installed so the unit could play silent with no ambient noise from the speakers when using headphones.  I don't know if there is another TABOO MK II with this particular modification. As noted above, the unit also has two variable inputs and a fixed input for use with a preamplifier.  This is a versatile amp that has a nice, relaxed gain, which can be varied by use of either a 12AU7, 12AT7 or 12AX7 input. The lucid mode is a nice feature to lend some spatial widening to some recordings.
The unit will be supplied with a pair of Russian Military 6P14P-EV (EL84 equivalent) tubes from the 1970's, a Svetlana Winged C 5U4G rectifier and a Sylvania 12AU7 input tube.
The replacement for this amp sells for $1,695. This unit with all the extras is being offered for $995
 plus shipping.
« Last Edit: 25 May 2013, 12:18 pm by rivieraranch »
Re: Decware Taboo MK II Headphone/Speaker amp
« Reply #1 on: 5 May 2013, 11:36 am »
Your location and reason for sale (I know you've been a big DecHead)?
rivieraranch
« Reply #2 on: 5 May 2013, 09:49 pm »
Reason for Selling: I switched this amp with a DECWARE SUPERZEN SE84CKC
at office setup.
rivieraranch
Re: FS - Decware Taboo MK II Headphone/Speaker amp
« Reply #3 on: 25 May 2013, 12:18 pm »
BACK ON THE MARKET AGAIN DUE TO BUYER BACKING OUT.
