Paradigm Studio 40 v3 Speakers (Sold)
0 Members and 1 Guest are viewing this topic. Read 4716 times.
Jbannas
« on: 3 May 2013, 09:33 pm »
I have a very nice pair of Paradigm Studio 40 v3 audiophile speakers for sale.
They are cherry finish and come complete with both original boxes and one manual.
They sound incredible, but are a little too large for my family room bookshelves.
I'd rate them a 9 out of 10, and have attached a link to a bunch of high resolution photos: http://s172.photobucket.com/user/jbannas/library/Paradigm%20Studio%2040v3?sort=9&page=1
Read the reviews here to see that they received all perfect 5 out of 5 ratings: http://www.audioreview.com/cat/speakers/bookshelf-speakers/paradigm-reference/studio-40-v3/prd_298868_4290crx.aspx
Sold
Specifications
Design 3-driver, 2-1/2-way bookshelf / stand-mounted
Crossovers 2nd-order electro-acoustic at 2.0 kHz;
2nd-order electro-acoustic at 500 Hz
(lower bass driver)
High-Frequency Driver 25-mm (1 in) G-PAL™ dome, ferro-fluid
damped / cooled, die-cast heatsink chassis,
IMS/SHOCK-MOUNT™
Bass / Midrange Driver 178-mm (7 in) S-PAL™ cone,
38-mm (1-1/2 in) voice-coil,
AVS™ die-cast heatsink chassis,
IMS/SHOCK-MOUNT™
Bass Driver 178-mm (7 in) mineral-filled polypropylene cone,
38-mm (1-1/2 in) voice-coil, AVS™ die-cast
heatsink chassis, IMS/SHOCK-MOUNT™
Low-Frequency Extension* 36 Hz (DIN)
Frequency Response:
On-Axis
30° Off-Axis
±2 dB from 62 Hz - 22 kHz
±2 dB from 62 Hz - 20 kHz
Sensitivity - Room / Anechoic 92 dB / 89 dB
Suitable Amplifier Power Range 15 - 180 watts
Maximum Input Power† 140 watts
Impedance Compatible with 8 ohms
Internal Volume 23 L / 0.8 cu ft
Height, Width, Depth 55.9 cm x 21.0 cm x 32.3 cm
22 in x 8-1/4 in x 12-3/4 in
(heights include spikes or outrigger
feet; widths exclude feet)
Weight (unpacked) 31.8 kg / 70 lb per pair
« Last Edit: 28 Jun 2013, 03:33 pm by Jbannas »
Flac2Dac
Re: Paradigm Studio 40 v3 Speakers
« Reply #1 on: 4 May 2013, 05:26 pm »
PM sent.
Jbannas
« Reply #2 on: 13 May 2013, 06:18 pm »
bump
