My old new sub-woofer!
0 Members and 1 Guest are viewing this topic. Read 2670 times.
budyog
  • I don't listen to audio, I listen to music.
« on: 3 May 2013, 03:39 am »
I had this old Velodyne ULD-18 cabinet in storage and I brought it back to life! I added 4 internal braces, spayed auto undercoating on the inside, added some foam to the sides along with the insulation that was in the cabinet, added new Dayton Audio BPA-38G binding post, 10 gauge wire and a Dayton Audio HO-18” driver powered by a Dayton Audio SA-1000 amp.
The cabinet is 6.3 interior cubic feet sealed and it sounds bleeping great! I hear low notes and tones I have never heard before, even at very low volume! The amp has a nice parametric EQ that you can fine tune, a very nice feature I did not have with my previous sub amp.
I am very happy with this sub-woofer set up, and it looks pretty good too!
neekomax
Re: My old new sub-woofer!
« Reply #1 on: 3 May 2013, 03:42 am »
Nice one, that's a fat sub! 18", yow!  :rock:
budyog
« Reply #2 on: 3 May 2013, 03:48 am »
Btw, this could easily be built for under $1000!
PMAT
« Reply #3 on: 3 May 2013, 04:19 am »
Nice! Here is a dead Legacy sub I bought for $20 on CL and re-soldered the tinsel leads to both drivers. Bought a plate 330 watt plate amp off CL for $30 and re-did the cabinet with homemade walnut veneer. Sealed twin 12 inch Sub. So tight and deep!
Started like this
Hand sawn veneer
Driver (balls)
Filled the hole where remote sensor was
Glued veneer on
Cut hole
Painted Black lacquer
Drivers installed front
Back
Paint,sandpaper and all about $80
budyog
