0 Members and 1 Guest are viewing this topic. Read 25332 times.
I didn't experiment directly between the Rega and VPI, but sitting on top of a Salamander Synergy rack on a suspended wood floor, the Classic was happier. When I had the Rega in my old place on a Solid Steel Target rack placed on a concrete floor, I was happy to not tweak the table. My system is in the living room so i want to keep it looking acceptable. I think the Salamander rack is still giving me some isolation problems, but upgrading it to some thing better that's still aesthetically pleasing will be expensive. I've changed the rack feet out for Herbie's grungebuster sliders as well as tenderfeet and iso-cups under most components.
It looks like they took a grinder to it. I thought they were going to replace it?Wayner
Good to hear you got it back, but it does look like they just ground it down.Did it solve your sibilance issue? How does it sound?
I've finally had some time to listen. The pivot was ground down by VPI. They first told me that it was was impossible to repair and then said they were able to repair it. I have been assured that the repaired pivot is fine and the replacement spike ($100) will not yield any sonic improvements. I do kind of wish they would have consulted me when they had the spike as I may have opted for the replacement just for peace of mind. VPI only charged me shipping to repair the spike. As far as the sound now, this sounds like different turntable. I could try to list out all of the audiophile jargon, but across the board every aspect is improved. I still have no clue how/when the pivot was damaged but I suspect now it may have been damaged from the start. I have been fighting with setting this table up for 3-4 years. I have the arm set exactly (Overhang, VTA,VTF) like it was before the repair. I did slightly shift the azimuth to the left as it was off by about 4 tics on the Fozgometer. I think this accounts for the bent pivot skewing the arm to one side.The right channel sibilance problem still pops up, but with much less frequency. So far I would say that it's dropped by about 70%. So it's definitely a step in the right direction. Once I get a better handle on the improved sonics of the table, I will recheck the arm settings and see if i can dial out the sibilance problem. I'm sure that the damaged pivot was contributing to the right channel sibilance. It hasn't completely disappeared, but I think I'm on the right track. I still can't believe how much better this table sounds now...
I am not sure what conclusion to draw. I think my example of the Zephyr may not be quite right - the stylus is a bit crooked relative to the cartridge body, although the folks at Music Direct said it was within "normal" range based on photo's I had sent. It also needs a healthy tilt to get the azimuth correct (both per a fozgometer and using the mirror method). I plan to send it to Soundsmith to have them take a look at it and see what they have to say.Thanks all for your input along the way.Tom
Tom,Glad you got things sorted out. With regards to the Zephyr, the cantilever is a little skewed or crooked, and azimuth is considerably off. This is a defective stylus. Chances are the cantilever is twisted. Music Direct should at the least, supply you with a new stylus. This is an expensive cart and would make a nice back-up or you could sell it with a new stylus. neo
New Spike (Does this look like a different material than the first spike?)
I am digging up this older thread to add the resolution in case anyone finds it in the future.Since last posting I fiddled with several things such as damping the tonearm with dots and plasticlay as Neo had recommended, different platform materials, etc. Nothing really made a difference on the mistracking issue (some sound differences yes, but the mistracking was still happening). I was in the process of investigating options to replace my VPI Scout as I was convinced the JMW-9 arm was at fault.Earlier this week, I was able to try a Dynavector 20X2L cartridge on my table. After trying so many things to solve this issue I was skeptical it would make any difference. Both my Grado Sonata and Soundsmith Zephyr had similar mistracking issues (less severe with the Sonota) so I had thought it was not an issue with the cartridge.After going through my routine setup process, I put on several of the records that had the worst sibilance distortion and mistracking issues with the Zephyr. The Dynavector tracked everything perfectly! No sibilance distortion, less inner groove distortion, no audible mistracking at all!Needless to say I purchased the Dynavector and plan to keep the VPI Scout.I am not sure what conclusion to draw. I think my example of the Zephyr may not be quite right - the stylus is a bit crooked relative to the cartridge body, although the folks at Music Direct said it was within "normal" range based on photo's I had sent. It also needs a healthy tilt to get the azimuth correct (both per a fozgometer and using the mirror method). I plan to send it to Soundsmith to have them take a look at it and see what they have to say.Thanks all for your input along the way.Tom
I have good news as well. After VPI ground down my original bent spike:Then, a few weeks ago, I got an email out of the blue from HW saying that he wanted to replace the spike and not leave me with a repaired one:When I received the new post back from VPI I noticed that the VTA adjustment ring is also different and fits much smoother. The original ring always had a little play in it. With the new spike, all I had to do was level the tonearm, quickly recheck my overhang, VTA and azimuth and the sound is Unbelievable! I cannot believe how much this small defect was affecting the tonearm. Over the past three years, I've tried 4 cartridges and every set up combination I could think of and found it impossible to dial this table in. I feel like I can finally hear what this table can do. Hopefully I didn't waste too many hours on my Benz Ref S trying to get it set up...Big Thanks to VPI customer service and every one who has chimed in on this board.
Tom, so how do you like the sound of the 20XL2?
