0 Members and 1 Guest are viewing this topic. Read 25327 times.
I was trying out some damping fluid on my JMW Classic arm and I noticed that the spike on the Unipivot base didn't seem as sharp. I'm gussing that this is a problem, but it may look worse magnified. Here are some pics from my cheapo USB Microscope:I've tried to be gentle with the arm, but maybe I bumped the spike at some point. I'm guessing this may be the cause of the sibilance I can't get rid of. The pics are from behind the arm base, so it's bent toward the platter. I've contacted VPI to see if they can help.
I have given this problem quite a bit of thought. So far, I think it's actually like 3 problems in one. The first is the lack of correct anti-skating. The stylus is riding the rail on the inner groove and slightly "stone skipping" on the outer groove. Unfortunately, the upper tenor/soprano area also seems to be a resonance frequency harmonic of the arm/cart combo, but that is maybe a guess. The third problem may be from azimuth "roll". But for this to happen, I have to ask if it seems to occur at a warped area of the record?One of the problems with uni-pivots is the rolling of the azimuth while in play. The cartridge will bob back and forth (to the record terrain) and loose firm contact with the record groove, and since the anti-skate is lacking, that groove is the outer groove (right channel).Soundsmith does have a cartridge that is made for the uni-pivoted VPI arm. Unfortunately it's about $1K.Wayner
"This spike is inverted - mounted on the base and point facing up?" Yes it points up and the arm balances on it."What is the height of the contact point relative to the arm tube and the plane of the record?" I'm not sure, but it looks to about on the same plane."Stainless steel spike?" I believe that it is Tungston Carbide"How is pivot damping implemented on the 10.5, at the base of the spike?" The damping fluid goes in the trough at the bottom of the spike. The bottom edge of the armwand makes contact with the fluid in the trough when it is placed on the pivot point.
Hey Tom, Is the spike on your arm damaged at all? I'm still curious if this could be the source of the problem.
Please take my estimation of the pivot point with a grain of salt. I haven't measured it and my pivot point is on it's way back to VPI. Maybe someone else can take a look at theirs and report back.
I checked out the spike on my arm and with 10x magnification it looks straight and the point is not flattened like yours.Reading the various posts here - along with several similar unresolved threads elsewhere - I am about ready to just give up and get another table. I bought the Scout used on a whim for a great price, and it has been good enough to revive my interest in vinyl. That alone has been worth the price of admission and I am really glad I purchased it. Maybe it is time to move on instead of investing more time, frustration, and money on the Scout trying to fix this issue. Even though the problem may be self inflicted due to the setup being off somewhere, it just shouldn't be this hard.
I had a Rega Planar 25 before the classic and although the Classic sounds much better I sometimes miss the simplicity of the more "nonadjustable" Rega.
Perhaps the O ring can be damped externally once azimuth is set? You could probably do it with one tiny damping dot, that is if you still have the problem. I don't know if this will cure the JMW 9, but it's worth a try.neo
Put a Rega RB303 arm on the VPI. That would be a hell of a deck, IMO.ner
I have never used that adjustment, the counterweight which also sets azimuth is more straightforward to use with the SoundSmith Counterintuitive for fine adjustment. Damping various parts of the arm would be something to try, and wouldn't cost much.Would herbie's thin grungebuster dots work, or is there something better to try?Here is a link:http://herbiesaudiolab.net/gb.htm
The Classic sounds much better, I wonder why?
