0 Members and 1 Guest are viewing this topic. Read 5269 times.
IF you can handle a bigger size - these are not bad at all, but like you said, a difficult find:Hsu HB-1 Mk2SHO-10You are going to have to give up something, either LF extension, box size or efficiency - just the laws of physics! And the price will start to skyrocket past your budget when you do-at least if you want high fidelity. Steve's options may fit your requirements though better than mine!Best,Anand.
Since you'll be listening nearfield, the 2 watts may actually be more than you think.
Since you'll be listening nearfield, the 2 watts may actually be more than you think.Even the little Pioneers that have gotten good reviews may work - they are ~90db and a fairly easy load.
There actually is a used pair of Orcas on Audio Asylum right now for $500. I hadn't considered them due to their published sensitivity of 89dB. But they do stress that's a conservative figure. Will explore.
Adding to what ltr317 said, the Hsu's are only 88dB efficient. The quoted measurement is in half space so you need to subtract 3dB to get the 'real' number. Home Theater magazine confirmed the 88dB in their review.http://www.hometheater.com/content/hsu-research-hb-1-horn-speaker-and-vtf-3-mk3-subwoofer-measurementsHere's a list I found: http://www.avsforum.com/t/1387083/list-of-reference-level-high-sensitivity-spl-speakers
