Heh,
Thanks, Hugh...
I guess I better treasure my remaining 4 lives left.
Ok, weird, weird, weird problem here.
Anyone can give me a take on this?
My AC mains voltage is 118.7V.
After the transformer, it is 37.8 AC.
Here is the weird one:
After the Power Supply PCB it is 25.3 VDC on the +ve rail, and 26.1 VDC on the -ve rail.
And for ALL 4 monoblock Power Supply PCBs!
What gives?
With such voltages, trying to bias the amps is futile (I tried):
The dismal results are:
Voltage at minimum bias:
R25 = 1.89VDC
R26 = 1.91VDC
Voltage across Speaker Output and Earth at minimum bias = 43 millivolts
Voltage between R5/R6 and Earth = 22.3V DC
Bias trim pot turned to maximum = 4.31 VDC across R25 (100R)
Voltage across Speaker Output and Earth at maximum bias = 10+ VDC
All these measurements are probably useless since the voltage after rectification is barely 50% of the supposed values.
Where did I go wrong?
Truly lost,
-Lost81
