How much power do a 14BSST2 use at idle?
0 Members and 1 Guest are viewing this topic. Read 1113 times.
turnovertherecord
  • rain,fog,snow,sun,known to happen on the same day
« on: 30 Apr 2013, 07:46 pm »
also is it overkill for focus audio FS-788 speakers :duh:
is a 20 amp outlet ok for power :scratch:
what is a used price range 5-6-7k
scb
Re: How much power do a 14BSST2 use at idle?
« Reply #1 on: 30 Apr 2013, 08:23 pm »
the manual on the Bryston website says:
POWER CONSUMPTION & HEAT LOAD
At Idle 215 Watts
At 600W 8ohms 1284 Watts
At 900W 4ohms 1980 Watts
tim92gts
« Reply #2 on: 1 May 2013, 09:51 am »
Presumably those power consumption figures are per channel?
Seems a lot but half seems very little!
Speedskater
  • Kevin
« Reply #3 on: 1 May 2013, 12:23 pm »
A 20 Amp circuit can handle 2400 Watts continuously,  that's 3 hours or more.
A circuit's design load should be 80 % or less of it's rated load.
Unless you listen to full volume test tones, an amp only use's a fraction of it's rated consumption. (while playing music or movies)
