Problem With My Oppo-105 Playing YouTube
0 Members and 1 Guest are viewing this topic. Read 5106 times.
cloudbaseracer
« on: 29 Apr 2013, 02:13 am »
I have made numerous calls to Oppo technical for help with this issue but I have not gotten a satisfactory answer.  It seems that my Oppo will not play a YouTube video without an unbearable amount of stops.  It is like it tries to buffer and will play for 1 second then stop for 3-4, then play for 1 second and stop for 3-4.  It will do this continually until I stop out of frustration.  I have changed the ip address 3 times under the direction of Oppo tecnical and have tried using the wireless connection and the wired connection with absolutely no difference.  The guy with Opp had me to do a connection speed test which is built into the Vudu software that comes on the player and that showed that I have a top self connection.  When I play a Vudu video it is skip free and works great. When I play a YouTube video on my laptop using wireless (the only connection I ever use) it works perfect and does not have any issues.
So, Oppo is telling me that there is "something wrong with YouTube in my area" and that it is not the player.  Oppo's premise is that since the 105 plays Vudu fine that it is not their unit or my connection. How is this possible?  Does this even make sense?
By the way, I use a Motorola DVR from Comcast and the sound is off from the picture.  Oppo is aware of this but does not have a remedy even though they have made "beta software" updates which I have installed.  I am finding that 2 out of 3 reasons I got the unit are not functioning properly. I got it mainly for music, which it plays great.
Any thoughts on the YouTube issue?
kc8apf
  • Are you sure what side of the glass you're on?
Re: Problem With My Oppo-105 Playing YouTube
« Reply #1 on: 29 Apr 2013, 03:51 am »
Doesn't sound like an issue with either you connection or the Oppo.  If it was your connection, Vudu wouldn't stream flawlessly.  It is actually possible that Youtube is misconfigured for your area.  They attempt to route traffic to the Youtube server that is closest to you.  Sometimes the information that feeds that decision can be wrong which causes your traffic to go to a far away Youtube server.  Sadly, there isn't a good way to figure this out and not really any way to report it.
WireNut
« Reply #2 on: 29 Apr 2013, 04:25 am »
Is that possible to check video's at other sites and see how it works?
Sites like MSNBC, CNN or others.
cloudbaseracer
« Reply #3 on: 29 Apr 2013, 05:08 am »
What do you mean by "misconfigured"?  Why does it work perfectly on my laptop?  I have never heard any of my friends complaining about YouTube issues in the immediate area.  All seems to work well through a computer.
cloudbaseracer
« Reply #4 on: 29 Apr 2013, 05:09 am »
Not on the Oppo.  It does not have a browser.  All sites work well on my computer though.
Rclark
« Reply #5 on: 29 Apr 2013, 07:59 am »
get a PS3. Their Youtube App is godlike.
cloudbaseracer
« Reply #6 on: 30 Apr 2013, 05:01 am »
Not convinced it would make a great dac though.....
Rclark
« Reply #7 on: 30 Apr 2013, 05:14 am »
Who said dac? Transport your audio out of the machine. You can use analogue RCA's or you can use optical, or the HDMI output passed to a dac...
mav52
« Reply #8 on: 30 Apr 2013, 12:44 pm »
Interesting thread on another site: http://forum.blu-ray.com/showthread.php?t=196706
cloudbaseracer
« Reply #9 on: 1 May 2013, 05:03 am »
Perhaps I missed it but is there something in there I was supposed to read that is related to my issue?
Austin08
« Reply #10 on: 1 May 2013, 07:03 am »
My boy and I were watching several videos about Universe by History channel on youtube with Oppo 105 and got no problem.
