grungebuster Dots under tonearm collars?
0 Members and 1 Guest are viewing this topic. Read 1973 times.
efhjr
  • Why, why, why, why are we sleeping?
« on: 29 Apr 2013, 12:43 am »
I'm wondering if grungebuster Dots under tonearm collars are a good idea. Anybody try this?
The collars I'm using are 69mm and 57mm, which don't quite match the sizes shown on the web site. Can I get thin grungebuster Dots cut to those sizes?
Herbie
    • Herbie's Audio Lab
Re: grungebuster Dots under tonearm collars?
« Reply #1 on: 30 Apr 2013, 03:14 am »
We have lots of customers using grungebuster Dots and grungebuster gaskets under tonearm collars and tonearm mounts. Grungebuster is a superb material for such a decoupling/isolation interface. You can get a thin grungebuster sheet, 5" x 8" and easily cut Dots or gaskets to any size and shape you like. With a 5" x 8" sheet, you'll have material left over for a jillion other potential decoupling/isolation uses.
grungebuster Damping Sheets
Steve Herbelin
Herbie's Audio Lab
