Doubling the 28B-SST2 outputs(not talkin power)
0 Members and 1 Guest are viewing this topic. Read 1012 times.
drummermitchell
« on: 28 Apr 2013, 04:04 pm »
Perhaps a Q for James:
Since I have two systems in one(HT+two channel)
I have been using the Balanced for audio only and single ended for HT.
Simply put I have a pair of single ended running up front for the 28's+two Xlr's.
Before I would when switching from HT to 2 channel I'd always unplug either the XLR's or single ended so that there would be only single ended or XLR's inputted in the 28's.
Since yesterday I have both single ended and XLR inputted to the 28's and use the balanced/single ended switch to change to HT or two channel,
I would assume that this fine as I'm sure the balanced/single ended switch would absolutely bypass the one I'm not using.
Everything sounds great as usual,so hopefully I don't have to keep connecting and disconnecting the rca's and XLR's,THX.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Doubling the 28B-SST2 outputs(not talkin power)
« Reply #1 on: 28 Apr 2013, 04:07 pm »
Hi Don
Yes you can use the switch and leave both types of cables attached.
James
drummermitchell
« Reply #2 on: 28 Apr 2013, 04:13 pm »
Perfect,thanks James :thumb:
