Bryston BP-17 Preamp review teaser
0 Members and 1 Guest are viewing this topic. Read 14414 times.
  • The Demo is Everything!
    • http://www.bryston.com
« on: 26 Apr 2013, 09:24 pm »
Hi Folks,
BP-17 Preamp review in the works - sneak preview on some of the comments:
"By the way, the BP17 is superb.
The distortion of your products is getting to be so low, I may toss my tube gear. Up until now, tubes and solid stage high-end gear had about the same amount of distortion, but it was even-ordered vs. odd –ordered.
Now, with solid state gear having distortion in the 0.000X range, the order of the distortion peaks are irrelevant. Now, it’s high fidelity (solid state) vs. “The Tube Sound”. "
budcook
Re: Bryston BP-17 Preamp review teaser
« Reply #1 on: 26 Apr 2013, 10:20 pm »
I just got mine a few days ago, number 0037.  I'm looking forward to hearing what others have to say about it.
Bud
m00nhawk
« Reply #2 on: 27 Apr 2013, 05:35 am »
Personally, I'd like to know what you say about it....   8)
budcook
« Reply #3 on: 27 Apr 2013, 03:17 pm »
I'd like to comment on how I feel about it but I'm not too articulate when it comes to describing how it sounds.  When I first turned it on I was pretty disappointed but it didn't take long before things improved to the point where it was clear there was something different about this pre-amp.  It's replacing a well broken in BP-25 and I already prefer the BP-17 with only a few hours on it.
A crude way of describing how I feel about it is how I felt when I went from the stock Sennheiser headphone cable to the Cardas balanced cable.
Let's just say I'm happy I chose the BP-17 over the BP-26.
The total remote control of the BP-17 is worth the price alone.
Bud
spinner
« Reply #4 on: 27 Apr 2013, 05:34 pm »
The total remote control of the BP-17 is worth the price alone.    How is the 17 better than the 25? :scratch:
Bud
rmurray
« Reply #5 on: 27 Apr 2013, 05:55 pm »
 James are there any pix of the BP17 with the top off?  :)
« Reply #6 on: 27 Apr 2013, 06:03 pm »
No I am sorry I do not - it is the preamp section of the B135 Integrated amp.
James
budcook
« Reply #7 on: 28 Apr 2013, 02:22 am »
How is the BP-17 better than the BP-25?  Well, I didn't say it was better, I said I preferred the BP-17.  I don't know how to describe how it's different except to say that it just never sounds strident no matter what you feed it or how loud you play it.
I want to put a couple hundred hours on it and replace the DAC to Preamp IC with a Cardas Light and then I should know what I have.
I doubt I'll ever have buyer's remorse.
Bud
turnovertherecord
  • rain,fog,snow,sun,known to happen on the same day
« Reply #8 on: 2 May 2013, 02:21 am »
How much Gain does it have ???
budcook
« Reply #9 on: 2 May 2013, 02:33 am »
I don't know but it seems to have less than the BP-25.  On reflection, it might be due to the BP-17's lack of balanced inputs.  I used balanced with the BP-25 but single-ended with the BP-17.
Since I bought a BHA-1 headphone amp, I'm using the balanced output of the BHA-2 for that so even if the BP-17 had a balanced input, I wouldn't be able to use it.
I'm otherwise quite happy with the BP-17.
Bud
« Last Edit: 30 May 2013, 04:30 pm by budcook »
« Reply #10 on: 30 May 2013, 04:22 pm »
SUBJECT: Bryston BP-17 Preamp Review Secrets of Home Theater
Hi Folks
Please see link below for a review on the new Bryston BP-17 Preamplifier from The Secrets of Home Theater Magazine:
http://www.hometheaterhifi.com/preamplifiers/preamplifiers-reviews/bryston-bp17-stereo-preamplifier.html
james
turnovertherecord
« Reply #11 on: 30 May 2013, 05:02 pm »
Very nice
Great to see Bryston as always
Great products and the best customer service on the planet :thumb:
skunark
« Reply #12 on: 30 May 2013, 05:45 pm »
Is the BP17 "fully balanced"?    If not I would let the reviewer know.
The Design
The BP17 is fully balanced from input to output, meaning that each channel actually has two preamplifier circuits, with one path inverted. The two signals are combined at the output, and any electrical interference that gets into the circuitry along the way is cancelled out. I see more and more preamps and power amps in a true balanced configuration, and this is good.
budcook
« Reply #13 on: 30 May 2013, 06:52 pm »
I believe it's fully balanced.  It just doesn't have a balanced input.
« Reply #14 on: 30 May 2013, 07:10 pm »
Yes the ouput is a fully differential balanced output.
james
skunark
« Reply #15 on: 30 May 2013, 08:14 pm »
james
Can you re-read that text, without a balanced input, not sure how an pre-amp can be fully balanced, and I quote "fully balanced from input to output" regardless if it has a fully balanced output.   Is the B135 fully balanced too?
Jim
« Reply #16 on: 30 May 2013, 09:21 pm »
Jim
Hi
The inputs and circuitry is single ended.
james
So There
  • Brystonized
« Reply #17 on: 31 May 2013, 01:12 am »
Congratulations, James, on yet another stellar review. Excellence is Bryston's norm.
Rich
_______________
Whiney Napa Valley
« Reply #18 on: 31 May 2013, 01:17 am »
Rich
_______________
Whiney Napa Valley
Thanks - he called me to tell me the quality of the measured performance was at the limit of his test gear.
James
KeithA
« Reply #19 on: 31 May 2013, 02:14 am »
James
Are there any other reviews in the works from some of the more notable mags, etc?
I'm in the process of buying a new preamp to replace the 2 channel bypass I've been using on my SP1.7 (pretty close to pulling the trigger on a Pass Labs XP-20). My dealer doesn't stock any Bryston gear, so a demo is not possible. I'm fearful that the BP17 is too close to the SP1.7. However, a few more reviews might convince me to give the BP-17 a try.
Keith
