Audio Design Associates ADA Mach II Cinema Rhapsody SELECT SERIES Processor $550
0 Members and 1 Guest are viewing this topic. Read 3522 times.
Corradobrit
Selling a rare 'Select Series' ADA Mach II Surround Sound Processor that was recently removed from my HT. This is a standalone unit with isolation feet/pads and cosmetic upgrades. In excellent working condition.
High quality components used throughout and Made in USA. Originally $5000 new. Asking $550 plus shipping.
The Cinema Rhapsody Mach II is capable of over 25 processing modes including Dolby Digital EX, Dolby Pro Logic II, DTS ES, and DTS Neo 6. Also featured are THX Ultra 2 enhancements and several proprietary ADA processing modes including Quad Hex Bypass and Stereo 5.
This is a great sounding piece and in my opinion, if you don't need HDMI connectivity, is one of the best values out there as far as home theater pre/pros go. The Mach II features a 7.1 multi-channel analog bypass input so that you can connect your SACD or Blu-Ray player and experience the new high-resolution formats.
BONUS: Included with the unit is a $100 custom RCA to DB-25 cable that allows you to connect the DB-25 multichannel input to your Blu-Ray players 5.1 analog outputs. Also included is a copy of the manual and power cord.
Features:
Eight Analog Audio Inputs
Four Coaxial Digital Inputs; Four Optical Digital Inputs
Eight Composite Video Inputs; Four S-Video Inputs
Three Component Video Inputs
THX Ultra 2 Certified; Discrete 7.1 Analog Input
Dolby Digital EX, DTS ES Discrete Surround Modes
Dolby Pro Logic II And DTS Neo 6 Matrix Surround Modes
Additional DSP Modes Include Quad Hex Bypass and Stereo 5
Serial Configurable And Controllable Via ADA Bus Connection
Digital Inputs And Surround Modes Are Assignable To Sources
Attractive Front Panel Display for Operation and Setup
Two 12v Triggers
« Last Edit: 27 Apr 2013, 03:19 am by Corradobrit »
