BP-17 Won't Work w/BR-2
0 Members and 1 Guest are viewing this topic. Read 1023 times.
budcook
« on: 24 Apr 2013, 02:50 pm »
Just got the BP-17.  I bought it specifically because of it's remote control capability.  However, not one thing works with the remote including power, volume, input selection, Code control...nothing.
The BR-2 works perfectly with my BCD, BDP and BDA from anywhere in the room but the BP-17 won't work even with the remote inches from the sensor.
The BR-2 is something less than 2 years old.
Are there different versions of the BR-2?  Shouldn't the BP-17 work with it?  Anyone have a suggestion?
Thanks in advance,
Bud
  • The Demo is Everything!
    • http://www.bryston.com
Re: BP-17 Won't Work w/BR-2
« Reply #1 on: 24 Apr 2013, 04:26 pm »
Thanks in advance,
Bud
Hi Bud
Call Mike Pickett at Bryston - he is the remote expert.
james
budcook
« Reply #2 on: 24 Apr 2013, 04:35 pm »
I called Mike and the problem was solved in a couple of minutes.  The code for the BP-17 is 712.
Works great!
Bud
