Do I need to use wx2 crossover
0 Members and 1 Guest are viewing this topic. Read 2137 times.
mswobo
  • always after better sound need a money tree
« on: 17 Apr 2013, 05:45 am »
I have 2 vandersteen  subs with my 2ce's...do I need to use the wx2 or can I just go from amp to preamp ?
dminches
Re: Do I need to use wx2 crossover
« Reply #1 on: 17 Apr 2013, 11:53 am »
Which subs do you have?  Are they speaker (2Q) or line (2W) level?
If they are the Qs then you need the crossover.  Otherwise, all the low bass information will be sent to the 2CEs.  That's my understanding of what the crossover is doing.
mswobo
« Reply #2 on: 17 Apr 2013, 12:42 pm »
they are 2W
dminches
« Reply #3 on: 17 Apr 2013, 01:13 pm »
I should have said 2W(q) or V2W.  It sounds like they good hooked via speaker level which means you should use the crossover.
mswobo
« Reply #4 on: 17 Apr 2013, 03:41 pm »
pijtoo
« Reply #5 on: 29 May 2013, 03:57 am »
I have 2ce's, a 2w sub and vcc-1. I use the crossover and the bass couldn't be smoother!! Enjoy!
