0 Members and 1 Guest are viewing this topic. Read 43110 times.
Man, I need to hear this speaker. Maybe 2 of them.
Any plans for baby brothers? Say 10" or 12" woofers?The Nimbus physical specs are a bit intimidating. I can deal with big SS amps. Weight: ~250lbsDimensions: 53" H (from floor to peak) x 17.5" W (at the woofer center) x 26" D (including rear wall curve)Recommended amps include everything from low powered SETs to 1000W + Solid State amps.
I suppose we could just lie about our specs like most other manufacturers do
Yep. You didn't know that's an industry standard?
I do look forward to your full set of measurements though as discussed in another thread at some point. It may have been this one.
Yes, unfortunately I did. I have that conversation with customers every day it seems, what's possible and what isn't in terms of specs.
I have plenty of measurements obviously, there's a basic on-axis FR on the website.
The vast majority of customers don't seem to care about measurements however, and honestly it confuses some.
Can't get the Nimbus out of my head. You mentioned their ability to fill a large room, but what about smaller spaces? What kind of listening distance is needed? How close to the rear wall can they be? What would be the smallest room size you'd recommend for these?
