0 Members and 1 Guest are viewing this topic. Read 3925 times.
I use two hampsters with treadmills. Though sometimes they run out of power if I forget to refill their food and water. YMMV.
I would think that the dampening factor would be a mute point as SS and Class D both have sufficient Dampening Factors, or do they? Jim
The problem with pro amps is the fan noise.
A well designed sub cabinet can virtually eliminate most if not all vibrations.
However, reliability is a valid point. Which is the more reliable type of plate amp? Which sounds better?
The only plate amps I know about with consistently good recommendations from users are from a company called O Audio. They recently closed up shop though. Various Parts Express plate amps are known for reliability problems. So I don't know of any, and even if I did, I wouldn't recommend using them, for reasons I've already mentioned.
I've heard that class D is excellent for subs and would like to hear from those who have first hand experience. Better yet, those who have experience with Class D and other types of amplification for subs.
