BDP-1 which MPD ver. to run on FW S1.70 2013-04-09 Build: Loony Loon (RC1)?
0 Members and 1 Guest are viewing this topic. Read 1181 times.
BrystonNut
  • Bryston, there is no substitute!
Hi y'all,
I just found this fantastic website a couple of days ago...forgive me if this topic has been posted already...I did a search but couldn't find an exact answer to my question.
In the SETTINGS menu under MPD, there are 3 versions, 0.15.12, 0.16.8, & 0.17.2. Which is the correct setting or can any of the 3 be used?
There is a warning. "*These settings (above) should not be changed unless otherwse advised to do so."
Couldn't help myself, I see the warning as a chance to learn... so I changed to the latest, assuming it would be the best overall.
Any thoughts or info would be great! :beer:
skunark
You can always review the MPD release notes:
http://git.musicpd.org/cgit/master/mpd.git/tree/NEWS
I would stick with the default version unless you noticed an issue that the above link addressed then sure give it a try.   Make sure to restart rebuild the database if you do upgrade.
Jim
unincognito
    • bryston.com
The different versions support certain files differently and mostly effect support for wav, m4a and accessing files from a NAS.
Chris
