Hegel H100 Integrated amp Mint Condition
0 Members and 1 Guest are viewing this topic. Read 3656 times.
blackhawks6
« on: 12 Apr 2013, 01:18 am »
The performance of this Hegel 120 wpc Integrated amplifier with built in DAC is out of this world. I am the second owner of this unit which I purchased from a neighbor here in the Boston area. He purchased it from Goodwin's which is a local high end Hegel dealer in Waltham MA and owned it for 3 weeks. The sound that this unit reproduces is nothing short of amazing. It has a 16 bit capable DAC and the DAC sounds as good as my W4S 2 DAC did and the USB DAC is no hassle plug and play. This unit was purchased February 19th new from the dealer. My neighbor upgraded to an H200 and I have likewise been so floored by the performance of this unit that I upgraded to a black Hegel H300 which also has a built in DAC (seen in 1 picture). This Hegel piece is in pristine condition...not a mark on it and is broken in (run in time on these runs about 200 hours). Comes with everything including original sales receipt. You will not come close to the level of performance of the H100 at this price point. Includes all original packaging including milled aluminum remote.
Buyer to pay FedEx insured shipping. Any questions, Tony at 617 448 5433. Thank you.
Technical Details
Output power: 120W + 120W in 8 ohms, 220W + 220W in 4 ohms
Volume, Input source and mute controlled by Hegel RC2 remote
Inputs: 4 Unbalanced (RCA), balanced (XLR) and USB
Home Theatre input: maximum level power amp input (RCA)
2 pcs Pre Out (RCA), 1 pcs Recording output (RCA)
Speaker outputs: One pair of heavy duty gold plated terminals
USB resolution: 16 bit / 48 kHz, Plug & Play. No drivers needed
Input impedance: Balanced 50kohm, unbalanced 11kohm
Analog frequency resp: Less than +/- 0.2 dB deviation 20Hz-20kHz
Signal to noise ratio: More than 100dB
Crosstalk: Less than -100dB
Distortion: Less than 0.005 % at 50W i 8 ohm
Intermodulation: Less than 0.01 % (19kHz + 20kHz)
Damping factor: More than 1000
Power Supply: 630VA, 67 000uF capacitors
Output stage: 8 pcs 15A 150W high speed bipolar transistors
Power consumption: 30W in standby switched on
Dimensions/weight : 10cm x 43cm x 42,5cm (HxWxD), weight 16kg
Dimensions/weight US: 4" x 17" x 16,7" (HxBxD), weight 35,2 lbs
blackhawks6
Forgot price: $2100.00 on AudioCircle ($3000.00 new)
