Switch elimination
0 Members and 1 Guest are viewing this topic. Read 1336 times.
ZAKski288
Switch elimination
« on: 12 Apr 2013, 12:10 am »
Just want to run it by the VMPS experts.  I have a pair of towers and want to eliminate the bi-amp toggle switch.
I'm thinking basically  combine #2 with #3, and combine #5 with #6 . Cut jumper wire, and remove wire from lower
binding post.
James Romeyn
Re: Switch elimination
« Reply #1 on: 29 Apr 2013, 03:39 pm »
Sorry to be harsh.  Two facts prove, unequivocally, you are absolutely incompetent to perform the intended task:
You do not know the internal operation of a DPDT toggle switch, one of the most basic switches in the known universe.
You propose to eliminate integral crossover component and it never occurred to you to disclose to readers what position you employ the switch.
Stay away from soldering iron.  Leave those speakers alone and enjoy them.
PS: I have two spare Focal fiberglass domes in superb condition for those, $100/pr + shipping.  If you ever need one later, not likely easily found.
