0 Members and 1 Guest are viewing this topic. Read 3566 times.
I will try and explain the BS about balanced line for home audio one more time.There are two ways to do balanced line equipment. The right way is to maintain four separate internal audio electronic channels, left plus, left minus, right plus, and right minus. This costs essentially twice as much as single ended equipment, and for a vacuum tube preamp the real estate needed would be huge.The cheap and dirty way is to add additional circuits at the input and outputs of the normal internal two single ended circuits to convert the balanced line signals back to single ended for internal use and then to convert singled ended to balanced out. This simply adds additional circuits to your unit doing absolutely no good for you at all.Balanced line is nice for low level mic signals in an electrically noisy live stage environment or in a studio chock fulla equipment because it can cancel common mode noise.Note since balanced line will increase the signal level by 6dB, and because almost all will judge louder is better, much of the appeal for balanced line is because it makes everything a big louder.However, technically and logically it useless for home audio, just another fancy catch phrase that makes the equipment more expensive.Frank Van Alstine
Bumping this thread so I don't have to start a new one...I'm looking for recommendations on full tube preamps in this price range, probably used. My amp is solid state, don't care about balanced connections.Any faves? Remote preferred, but I'll sacrifice if the pre is good enough value.
I will try and explain the BS about balanced line for home audio one more time.There are two ways to do balanced line equipment. The right way is to maintain four separate internal audio electronic channels, left plus, left minus, right plus, and right minus. This costs essentially twice as much as single ended equipment, and for a vacuum tube preamp the real estate needed would be huge.The cheap and dirty way is to add additional circuits at the input and outputs of the normal internal two single ended circuits to convert the balanced line signals back to single ended for internal use and then to convert singled ended to balanced out. This simply adds additional circuits to your unit doing absolutely no good for you at all.Balanced line is nice for low level mic signals in an electrically noisy live stage environment or in a studio chock fulla equipment because it can cancel common mode noise.Note since balanced line will increase the signal level by 6dB, and because almost all will judge louder is better, much of the appeal for balanced line is because it makes everything a bit louder.However, technically and logically it useless for home audio, just another fancy catch phrase that makes the equipment more expensive.Frank Van Alstine
The Rogue Metis is $1495 new I believe.For $2000 and less, I think the Transcendent Grounded Grid is stupid good. $495 as a kit, and $899 fully assembled.
