Rogue Tempest and Squeezebox Touch question
0 Members and 1 Guest are viewing this topic. Read 768 times.
Bigfishhk
« on: 9 Apr 2013, 07:15 pm »
I have a strange issue with my Rogue Tempest 2 Integrated using Squeezebox Touch as source. Maybe someone can shed some light on it.
When starting to play the SB touch it doesn't play LEFT channel for a minute or so. Usually after a bit, sound comes out left channel and stays playing on both channels.
I have checked all interconnects and tubes. They are good.
Also I might add that with cd player as source the problem pretty much goes away. Usually there is sound in left channel or it comes on much faster, say  after a few seconds delay.
Tempest 2 is passive line stage amp. From the little I know it takes power from the source so maybe that's a clue?
Thanks for your advice.
Tom
