0 Members and 1 Guest are viewing this topic. Read 20206 times.
If you you have Magnepan's and drive them with tubes, please let us know. I run my 2.5's with a Audio Research VS-110, which is rated at 100 watts per, closer to 110. It makes joyous music with the maggies.Who's next?Jim
Go, Bernie!Unless you're in a gigantic room an ARC 150 should be sufficient, I would think.
ARC and Maggies, a classic combo . So 100 watts is enough to make the 1.7´s sing. Both ARC REF150 and Pass XA100.5 are on my shortlist of amps to consider for my 3.7´s but I´m concerned that they might be underpowered at 150/200W. What are your thoughts?
I'm not complaining and they drive my 2.5's as loud as I can stand them! Jim
We will see, the room is pretty large 6x8m with 2,5-3.5 high ceiling and widely opened to two other rooms.If it doesn't work, I can still use it as a room heater and xmas decoration lights.
Berni, if you get the chance to hear the REF150 with your 20.1´s, please let us know how it works
I run a pair of 1.7’s with a McIntosh C2300 tube preamp and a pair of MC275LE tube power amps. I run the power amps in parallel mode making the output 150 watts each. It sounds amazing. I have two subs in this two channel system, but I do not use them. The low end response of the 1.7’s and the McIntosh gear is surprisingly good. I tried the MC275LE amps with my 3.7’s. While the sound was all there, real or not, I felt that I was loosing something. Normally they are driven by 500 watt SS monos.I am entertaining getting a higher power tube amp for my 20.7’s, just to see (hear) what the 20.7’s can do. Right now I have SS Krell monos driving them. If I stay in the McIntosh line, they have the MC2301, 300watt mono tube amp, but I have not read a lot of comments about this amp.
... before they started their move into their new building (a work in progress), they had a pair of MC2301's hitting their 20.1's and it was sublime, both with and without subs. I would have to think they would slay the 20.7's as well. I just don't remember if they had them on the 20.7's when they came in or not. ...
They had them in their Topanga location in the first room on the right coming in the main entrance. Maybe they sold them. They only have one listening room set up in their new building when I was there about 3 weeks ago.Jim
Hmm, last I was in their previous location they had 3.7's in the first room and 1.7's in the second room. They used to have 3.6's in the last big room (when I bought mine). I guess I will have to chat up Stan. He usually calls me when he gets new toys in.Tim
I use a modified Dyna III with KT120s for mids on my T IV, but the mids are a BG Neo8 line array so it is not the same thing. But with the great sensitivity of the drivers (95 db the way I use them) I can run the tubes in triode. Tech says the amps do 30W cleanly on triode, 60+ watts on ultralinear, said it was the best performance on the scope he ever got from Dyna IIIs in 50 years in the biz. I can say with certainty that having a high sensitivity planar is what we should all want. Particularly so we can drive them to realistic levels with tubes for mids and highs. I don't think there is any advantage for tubes below 300 hz, so if you can biamp then you can really do well with tubes on top, though maggies will only make it marginally with a pair of 6550/kt88 per side for mid/tweeter. 4 kt88 per side is plenty for the mid/tweeter, but definitely not for a full size maggie in a large room - even with a sub.
Satie, I disagree...four 6550/KT88's per side is enough. I know of several with that setup who have big rooms and are not lacking for power in that setup. Jim
