0 Members and 1 Guest are viewing this topic. Read 3049 times.
What's your budget?
If i had $1500 to spend on a new preamplifier i think that i would buy a SAS Audiolabs 10A.you wont find anything else nearly as good as the 10A in the $1500 price range.
The Mytek would do the trick.Peachtree Nova preamp would also work, but since it doesn't have a volume bypass you would have to change the volume everytime you switched, but it has a remote.
