Easiest Route for Wireless?
0 Members and 1 Guest are viewing this topic. Read 856 times.
bside123
« on: 8 Apr 2013, 06:32 pm »
Didn't know exactly how to search for the answer to this question. If you know of a thread(s), please direct me too it. Thanks
My sister is attempting to set up a wireless system in her house. Here's what she's got so far:
1) MacBook Pro
2) External Hard Drive with Music
3) Verizon Network
4) SS Amp
5) SS Preamp
6) Speakers
7) Wires and Cable
8 ) iTunes
What is the best bang for the buck solution to stream the tunes from her MacBook/Hard Drive to the stereo? Apple TV? Etc.?
Re: Easiest Route for Wireless?
« Reply #1 on: 8 Apr 2013, 07:14 pm »
Does she have a WiFi network in the house? If so, one airport express will work. If not, she would need to get a router. The airport express has an analog out, which is not really an audiophile grade output but it will work for most people. The port is also a mini-toslink so it can be sent to an external DAC to upgrade the SQ.
bside123
« Reply #2 on: 8 Apr 2013, 07:17 pm »
She has a Verizon Wireless Network. Although she has some very nice "mid-fi" gear, she certainly doesn't need "audiophile" grade. Thanks.
skunark
« Reply #3 on: 8 Apr 2013, 09:21 pm »
Options...
Apple TV can work with or without a TV and you can choose between hdmi and optical.   If there's a TV connected to her stereo, then to me there's no other option for the money.  ($99 for ATV then $40 of monoprice optical dac (disable dolby-digital, i.e. pcm only)).  Configuration is rather simple with a TV with the included IR remote.
Airport express, as already noted, but use the mini-Toslink optical output over the minijack.  For whatever reason the optical output does a bit of buffering where the analog output doesn't.   You can pick up a reasonable mid-fi dac on monoprice.   How you connect the airport express to the Verizon router is important to understand:
Wired connection: should be easy to configure with the AirPort Utility
Wireless connection: you need to connect initially to the router to configure, and you need extend the Verizon router's wireless network (vs router/bridge mode).
Use an existing gaming console, blu-ray player and even a TV that has uPNP and install one of the many applications on her mac. Some might consider it difficult to integrate with itunes.
Sonos is another option, but priced a bit more but has a better internet radio interface than the Apple TV.
If she has an iphone or ipod touch, they make for great remotes to control and build a playlist otherwise use the IR remote for the macbook pro, which will help skip a track.  There's apps to control all the above.
