MiniDSP
0 Members and 1 Guest are viewing this topic. Read 9178 times.
Rick Craig
  • Selah Audio
    • http://www.selahaudio.com
MiniDSP
« on: 8 Apr 2013, 05:09 pm »
I have the MiniDSP 4x10HD here and am looking forward to working with it.  :thumb:
Re: MiniDSP
« Reply #1 on: 8 Apr 2013, 06:26 pm »
I've been using one for several years now, absolutely love it.
Rick Craig
  • Selah Audio
Re: MiniDSP
« Reply #2 on: 9 Apr 2013, 02:17 pm »
I still favor the DEQX but it's nice to have a lower cost alternative. The software side is the main issue here plus having a more complete package for my non-DIY customers.
aevans
Re: MiniDSP
« Reply #3 on: 12 Apr 2013, 06:03 am »
Rick, you should check these guys out: http://www.intersil.com/en/products/audiovideo/d2audio.html
It's a direct digital amp with built in DSP correction, the noise floor is damn near 0 from what I could tell.
I just auditioned the Vanatoo Transparent One that uses this tech and it's very nice for a desktop monitor. You can hear the cheapness of the Chinese drivers and boxes, but the DSP did it's job of cleaning up the response surprisingly well.
I know it's not your market, but it would be pretty sweet if you could come up with an active DSP corrected desktop monitor and hit that below $900 price range. Maybe some Founteks and seas drivers, although I've always thought a miniature ground plane CBT would be magic on a desktop.
Rick Craig
  • Selah Audio
Re: MiniDSP
« Reply #4 on: 12 Apr 2013, 04:34 pm »
Yes I had noticed those and it's a great idea they have. We are checking into something similar as there is quite a bit of action going on in the DSP arena right now.
ricardojoa
Re: MiniDSP
« Reply #5 on: 4 May 2013, 07:32 pm »
Hi Rick,
are there any significant advantage and improvement in turning the tempesta in to a dsp setup, with +/-1 on axis and assuming off axis remaing as good or better?
Rick Craig
  • Selah Audio
Re: MiniDSP
« Reply #6 on: 5 May 2013, 02:12 am »
Hi Rick,
If the software and hardware is optimal DSP will always have an advantage over passive. The question then is it worth the extra cost of the DSP unit and extra channels of amplification? In this case probably not since the passive design already performs very well.
studiotech
Re: MiniDSP
« Reply #7 on: 5 May 2013, 03:54 am »
Eagerly awaiting your impressions of this unit.  We are considering the same thing to replace the ancient BSS Omnidrive running the mains at the studio.  The BSS is making funny sounds on a random basis and at this point it is not worth the $500 repair fee.  I'd rather put that money towards a newer processor.  If the MiniDSP doesn't perform well or sound fantastic, we're just just going to go with a Digmoda, because I've already been using them with good success.
Greg
ricardojoa
Re: MiniDSP
« Reply #8 on: 5 May 2013, 02:21 pm »
Thats true, there are always extra cost for the amps.
Rick Craig
  • Selah Audio
Re: MiniDSP
« Reply #9 on: 5 May 2013, 09:16 pm »
Greg
Having worked with DEQX and Digmoda I am curious to see how the software works. I'll let you know when I get a chance to listen.
Rick Craig
  • Selah Audio
Re: MiniDSP
« Reply #10 on: 11 May 2013, 04:00 pm »
Greg
So far so good. The software interface is easy to use - nice graphics and a few extra features as well that the Digmoda software doesn't have. I would prefer to have an on-off switch but other than that the hardware looks to be acceptable. The balanced out Phoenix connectors save them space and money; however, if I needed balanced outputs I think this would be a pain.
DS-21
Re: MiniDSP
« Reply #11 on: 15 Jul 2013, 02:42 am »
***I would prefer to have an on-off switch but other than that the hardware looks to be acceptable. The balanced out Phoenix connectors save them space and money; however, if I needed balanced outputs I think this would be a pain.
You could use the 12V trigger input to make an on/off switch.
But you shouldn't, IMO. The miniDSP's do have one flaw, and that's turn-on/off thump. I keep my 8x8 up all the time, and hooked up to a UPS.
Rick Craig
  • Selah Audio
Re: MiniDSP
« Reply #12 on: 15 Jul 2013, 04:36 am »
Yes, the thump is a shortcoming. I use a DEQX and amp that both have relay protection so I don't have to worry about that.
bill13
Re: MiniDSP
« Reply #13 on: 12 Nov 2013, 08:43 pm »
When I accidently pulled the power plug on my mini-DSP, a very nasty full scale turnoff transient damaged and nearly blew out my RAAL 140-70D ribbon even though there was a series protective 30uF  capacitor between the power amp and the RAAL(!)   :o
There was a small amount of visible thermally-caused damage to the center of the RAAL ribbon caused by the turnoff transient.   However,  distortion measurements (STEPS) still seem about the same as before -      But just knowing that the appearance of the thin ribbon element has changed, motivates me to eventually replace the ribbon assembly per the instructions posted on UTUBE.
This large turnoff-transient 'bump' that occurs with the mini DSP reflects a fatal/careless engineering design flaw, IMO -- an especially egregious shortcoming because the miniDSP is
intended for experimenters and hobbyist crossover designers.   :nono:
Thinking about adding a DC-storage cap at the DC-power input connector to the mini-DSP, plus a voltage sensing circuit & relay, to effectively disconnect my mini-DSP before a sudden loss of power can effect the output audio channels of the miniDSP.  :duh:
For the time being, I would hesitate to use my miniDSP on any driver except robust woofers and subwoofers which (may) be able to put up with this turnoff transient abuse!
Bill
Rick Craig
  • Selah Audio
Re: MiniDSP
« Reply #14 on: 12 Nov 2013, 09:26 pm »
Bill
Thanks for your feedback. One user suggested a UPS unit.
