0 Members and 1 Guest are viewing this topic. Read 28185 times.
No, I just learned about it the other day. It's a new model that's switchable between Class AB and Class A mode, and when it's in Class A, it automatically switches to Class AB above 35 watts. Sounds interesting, no?
I did have what I consider a seriously powerful amplifier in the Pass X350 – capable of pushing 700W into 4 ohms (the first 40W, or so, into 4 ohms being class A). That bias meter on the front was an indicator of the departure from class A – when it was 'at rest', the amp was running in lovely class A. It was a terrific amp with the MMGs because it 'loafed' along in class A. It was a terrific amp with the 3.7s because it had the goods to render solid, tight, loud bass from them. It was superb with the 3.7s after introducing the XO, because it spent lots of its time in class A (didn't take long to fall in love with that sound). How could I not answer the call of the obvious? I either wanted to try 100W of class A or something in that range from a valve amp. I'm not going to deny coveting a pair of Pass mono-blocks, but I designed and constructed my cabinet with a single (main) amp in mind – hence, its prominent location. Had I gone that route, I think they'd qualify as 'big guns'. I ended up with a 150W valve amp, which is no small potatoes, but it doesn't qualify as monster power – insufficient, actually, to drive the 3.7s full-range (no big deal because I didn't buy it for that purpose).I have no objection whatsoever to a thread celebrating seriously powerful amplifiers, but there is no 'one size fits all' statement which can be validly made regarding power requirements (or which technology is 'best'). Context, as with all things, matters. There are many variables to consider. In fact, I wasn't at all surprised at the results when I tried it. Volume and dynamics weren't issues, but the tautness of the bass was. Prior to redirecting the bottom end away from the 3.7s, which, by the way, is not something I regard in a negative light at all - it's something I prefer as a matter of course. To my ears, the midrange and lower bass approaches the quality of a good pair of stats when the panels aren't asked to reproduce deep bass. It's one choice among many, but it's one that I make without the slightest regret.Don't forget that I previously did have big power on tap. The 3.7s managed to draw heavily on its reserves when driven full range. I witnessed radical rotation of the meter on the front of the X350.
Does anyone here have one? It sounds pretty promising according to the review.
Nice review on the NewClear amp.http://www.tonepublications.com/review/the-newclear-nc1000/
Were you considering the XA100.5´s by chance?
Yes, those are exactly what I had in mind (if not the 160.5s). They are pretty costly, though. I lucked into something else. I'm not at all unhappy with what I chose, but I am curious about those XA amps - beauties.
I suppose, if you're looking for 35 watts of class A power with a bit of room above that. . I'd be more interested in the big XPR's and what those would be like loafing along at a few percent of their rated output.
I'll chime in here.My 20.7’s are driven by Krell 400e monos: 400 watts 8 ohm, 800 watts 4 ohm. Both pairs of 3.7’s are driven by Emotiva XPA-1 monos: 500 watts 8 ohm, 1000 watts 4 ohm. My one pair of 3.5’s are bi-amped with XPA-1 monos as well. The tri-center is a CCR and a pair of MMC2’s each with their own XPA-1’s. And lastly, my MGSS1 ‘s are also driven by their XPA-1’s. All in one home theater.I am not too tempted with the new XPR-1 mono. Double the power? I think I have enough already.
I dunno, that Class H power supply makes me nervous . . .
While I respect people's choice to keep their systems sotto voce, playing maggies with a SET, I don't get my kicks from ethereal beauty and tonally live images alone.
What makes you say that?
Class H amps have a reputation for being problematic. Here's a thread that discusses some of the issues:http://www.diyaudio.com/forums/solid-state/68415-class-h-amplifier.html
