Gas Grill recommendations?
0 Members and 1 Guest are viewing this topic. Read 19333 times.
Charles Xavier
Re: Gas Grill recommendations?
« Reply #60 on: 25 May 2013, 01:31 pm »
Carusoracer,
Late to the party here, but I can endorse the Charbroil Infra Red Bistro Gas Grill.  Small, efficient, heats up fast, no flame ups and easy to clean.  It won't impress friends, no side burners, no multi zone heating, just fast efficient cooking that I have found to be super.  I ordered mine from Amazon: http://www.audiocircle.com/index.php?action=post;topic=115726.40;last_msg=1227353
Good luck with your decision.
Bad link
http://www.amazon.com/Char-Broil-Infrared-Patio-Bistro-Grill/dp/B002DM5DV4/ref=sr_1_1?ie=UTF8&qid=1369488732&sr=8-1&keywords=Charbroil+Infra+Red+Bistro+Gas+Grill
rockadanny
« Reply #61 on: 30 May 2013, 09:08 pm »
Proud new papa of a Weber Genesis E-310 Espresso Gas Grill with three stainless burners and 18 mos. financing. Delivered today!
(stock photo - mine has the controls on the front instead)
hansmatt
« Reply #62 on: 30 May 2013, 10:39 pm »
Love my Weber...going on 12 years with only a replacement of grates & starter.  That being said, I just started using GrillGrates, which are aluminium grates which sit atop your existing grates.  Aluminium heats up fast, and leaves gret grill marks, but the real benefit is the bottom of the grates is solid with holes for juices.  The close bottom surface gives a very close heat element, rather than simply hot air from the gas jets.  It does a great job of searing meat without burning, but more importantly it prevents flare-ups with greasy/oily/fatty foods.  My first go-around with burgers & they were claimed the "best ever" by my family.
I have no relationship with the company...but it does up the quality of your grilling.
TrungT
« Reply #63 on: 30 May 2013, 10:57 pm »
Congratulations.  :thumb:
Great choice, you gonna to love it.
rockadanny
« Reply #64 on: 31 May 2013, 02:10 am »
Thanks TrungT! Wouldn't you know it - out of gas! Cannot fire it up until tomorrow.
I'm thinking salmon with stuffed jalapanos. Yum!
Bob in St. Louis
« Reply #65 on: 31 May 2013, 02:53 am »
....... stuffed jalapanos. Yum!.....
You mean "ABT's"?  :wink:
Crimson
« Reply #66 on: 31 May 2013, 02:58 am »
 :beer:
Good choice!
EDS_
« Reply #67 on: 31 May 2013, 03:50 am »
Just spend $150-$200 to get a decently constructed grill of a size that meets your needs, then get GrillGrates!  These things rock!  I'm getting arond 700 degrees F on the surface with a $200 Wal-Mart grill.  I think adding them to a regular grill beats almost anything you can get "stock" up to around $500 or so.
I want to thank you for the GrillGrates recommendation.  Currently we have a couple of smokers and a Charbroil "Infrared" gas grill.  The original grates lasted about six months before rusting.  I bought GrillGrates about six weeks ago due to your endorsement.  They are a must for me from now on.
Rob Babcock
« Reply #68 on: 31 May 2013, 03:57 am »
Glad to see they're working out for you!  Yeah, that's the problem I've continually read about in reviews of the Charbroil Infra grills- they're made of some kind of steel that rusts pretty fast.  The GrillGrates are anodized aluminum and don't seem to corrode at all.  My infrared thermometer reads temps of around 700 degree F on the top of the GG's!  Pretty good for a home grill, and not far from the temp we run the broiler I cook on at work.  They do indeed do as good a job as advertised at minimizing flareups.  I can grill burgers of 73/27 and not get a grease flare up.
TrungT
« Reply #69 on: 31 May 2013, 03:38 pm »
"out of gas" been there done that  :rotflmao: , really bad when 1/2 way cooking.
Now, with natural gas  :thumb:
Thans Rob for the GrillGrates suggestion.
Beside buggers and steaks:
Bacon and sausage (low setting on outside burner, center off).
Pizza (low on all)
 :thumb:
Rob Babcock
« Reply #70 on: 31 May 2013, 06:48 pm »
Mmmmm...that looks tasty! :thumb:
gregcss
« Reply #71 on: 9 Feb 2014, 06:38 pm »
I have a Weber with cast iron grates that I'd like to replace, as well as the 'flavorizer' bars. Looks like GrillGrates is highly regarded here. So these just sit atop the existing grates? Do they slide around when flipping food?
TrungT
« Reply #72 on: 9 Feb 2014, 06:51 pm »
It's just sit on the top of the existing grates and it stay put.
gregcss
« Reply #73 on: 9 Feb 2014, 07:53 pm »
Does food ever stick?
David C
  • Don't try and lay no boogie woogie on the king
« Reply #74 on: 9 Feb 2014, 08:29 pm »
I have the Weber shown above and the Grillgrates. Both are value for money. The grillgrates heat up quickly and I have not had a problem with food sticking, even fish. Would recommend both.
david
TomS
« Reply #75 on: 10 Feb 2014, 12:31 am »
On my Weber Genesis the Grill Grates replaced the existing grates, not on top of them. Fit like a glove and they are terrific!
chip
« Reply #76 on: 13 Feb 2014, 05:48 pm »
Grill grates look like something I will have to add. Just need to measure to see what size I need.  :thumb:
gregcss
« Reply #77 on: 12 Mar 2014, 03:09 am »
Just ordered 2 custom cut grillgrates to fit one side of the grill. Cant wait to grill with these.  :thumb:
TrungT
« Reply #78 on: 13 Oct 2014, 09:10 pm »
GrillGrate  :thumb:
Lemongrass, salt and pepper pork chops
