iPad with Audioquest Dragonfly
0 Members and 1 Guest are viewing this topic. Read 4884 times.
lextek
« on: 6 Apr 2013, 10:17 pm »
Playing around today with the iPad and Dragonfly.  Had to use a 5V power supply.
Bemopti123
Re: iPad with Audioquest Dragonfly
« Reply #1 on: 6 Apr 2013, 10:53 pm »
Here I have a sequence of questions:
What is the encoding of the files?
I see that it needs to be a AC bound system, what made you go this route rather than a Mac+USB+headphone route?
How does it compare sonically with a PC+DAC+headphone system?
Your setup is surely ingenious.
lextek
« Reply #2 on: 6 Apr 2013, 11:02 pm »
The files are iTunes AAC.  The black box holds 4xAA batteries so it is portable.  Usually I use the Macbook/Audivarna Plus, Bottlehead Crack amp.  But I was just experimenting.  The sound is quite good.  With the Macbook I can play hi-rez files (HD Tracks).  Nice if I want to take the iPad out on the Deck....
Bemopti123
« Reply #3 on: 6 Apr 2013, 11:53 pm »
How long do the batteries last?  Any audible degradation as the batteries discharge?
lextek
« Reply #4 on: 7 Apr 2013, 12:01 am »
Don't know yet.  Only put it together today.  Spent about and hour listening.  NiMH in pack.  I think if voltage drops too low the iPad will kick the Dragonfly.
