Suggestions for Surrounds for SCST?
0 Members and 1 Guest are viewing this topic. Read 1467 times.
Jdgate
« on: 6 Apr 2013, 05:47 pm »
Originally I was going to buy songtowers, with songcenter, and a couple sets of surround 1's.  However since this will likely be the speakers I will have to live with for a long, long, long time I have decided to sink the budget into the LCR and get the Supercharged versions of the Songtower and Songcenter.  I figure I could always upgrade the surrounds later to the surround 1's.  As such I do not have much that I can spend on surround speakers.  I have heard that NHT Superzero 2's at $99 each could work well.  Anything else I should look at?  For reference the speakers will go in a room where the back surrounds will be about 15 foot from the front row of seats and about 11 foot from the 2nd row of seats.  I also have to be able to wall mount the speakers as the wife will not allow them to be on floor stands.
rohrej
Re: Suggestions for Surrounds for SCST?
« Reply #1 on: 9 Apr 2013, 02:10 am »
I am using my SCST mains with Martin Logan EM-C2 center and EM-FX2 surrounds and am very happy with the setup.  The voicing of the speakers seems to blend very well.  The FX2s are wall-mounted as you specified.  I also found mine used, but they were still a bit more than the superzeros.
Saturn94
« Reply #2 on: 9 Apr 2013, 03:17 am »
My NHT SB1 bookshelf speakers worked great as surrounds with my HT2-TLs.  I wouldn't hesitate to recommend NHT for surrounds until you can upgrade to "matching"  surrounds.  As a matter of fact, my NHT AudioCenter 2 center channel also worked great with my Salks.
Jdgate
« Reply #3 on: 9 Apr 2013, 03:23 am »
Just a bit more.... :wink:
I would like to jump up to that category of surround but the budget just won't push it.  We are finishing the whole basement, and since I am getting family to provide labor (except for carpet), my home theater budget is as much as the whole rest of the basement.....including a built in office.  I had to cut the budget for surrounds way back to make it work.  I am resisting the temptation to go overboard on a custom veneer since that would make me drop some other component out.  We already have a 14 foot shuffleboard made from locally sourced Michigan hard maple with a chestnut finish (something about the craftsmen out there in Michigan seems to draw me in).   Jim said he should be able to dye match it so I think I am going to try to stick to that instead of introducing even more different wood tones to the room.....however that temptation is still nagging me.
Jdgate
« Reply #4 on: 9 Apr 2013, 03:26 am »
Thanks for the good words about the NHT.  A friend has the original superzeros for surrounds and I thought they worked out well in his system.  I also messaged Dennis Murphy about the new Superzero 2's and he thought they should work out great.  Said they were very neutral.  I think I will give it a shot.
