High Sensitivity 3-way
0 Members and 1 Guest are viewing this topic. Read 15168 times.
Rick Craig
  • Selah Audio
    • http://www.selahaudio.com
Re: High Sensitivity 3-way
« Reply #20 on: 9 Jul 2013, 04:07 pm »
I spent some time yesterday testing the drivers. As I suspected the sensitivity matching isn't conducive to a passive crossover. The edge resonance on the midrange (common with a driver like this) also makes it difficult to have a smooth response and reasonable impedance around the dip with passive correction.
Padding the woofer by reducing the gain is actually a good thing in this case since it allows more headroom for the bass extension equalization. I did a trial run with a moderate amount of EQ applied and it measures very well. I tried a few different crossover points and the sound is very clean.
aevans
« Reply #21 on: 10 Jul 2013, 05:11 am »
Isn't DSP is the best thing since sliced bread?
The little bit of fooling around with it that I've done it seems like a good idea to start with the most efficient drivers you can and eq your way down to a nice flat response.
Rick Craig
  • Selah Audio
« Reply #22 on: 5 Aug 2013, 09:48 pm »
Here's the sealed box bass response with the MiniDSP and equalization.
cstory
  • Seaching for clues
« Reply #23 on: 7 Aug 2013, 07:01 pm »
That certainly looks nice. Very flat with good extension.  :thumb:
So, do you need multiple amps for this system?  :?:
These speakers are interesting to me as we are trying to go off the grid with solar electric and I picture something efficient like these speakers combined with Red Wine battery amps being perfect for that situation. But if you need to buy 3 stereo amps it certainly changes the economics of that plan.
Rick Craig
  • Selah Audio
« Reply #24 on: 7 Aug 2013, 11:26 pm »
Yes, tri-amped in this case.
cmryan21
« Reply #25 on: 1 Feb 2014, 11:39 pm »
Rick, any updates on this project? Any cabinet pics or dimensions you can post?
Rick Craig
  • Selah Audio
« Reply #26 on: 3 Feb 2014, 03:39 pm »
Here's a picture of the cabinets...
loving_it
« Reply #27 on: 3 Feb 2014, 10:17 pm »
Very Nice
JohnR
« Reply #28 on: 4 Feb 2014, 07:48 am »
Whoa!!! That is incredible work! Holy cow.
oskar
« Reply #29 on: 4 Feb 2014, 04:22 pm »
That is just off the chart! Is there a right angle anywhere?
Do you veneer after box assembly or are the panels pre veneered then assembled.
Superb work.
delwon
« Reply #30 on: 4 Feb 2014, 10:01 pm »
Hello folks. I just registered because Rick Craig mentioned to me that he was posting a picture of the cabinets I did for this collaborative project here. As far as Oskar's question, I never thought about it, but since he asked, I thought about it and there is not one right angle on the cabinet. The build as you can imagine, wasn't simple. My brain started to hurt as I tried to figure out all the angles. With the cost of the kappa burl veneer, I was concerned that I might mess up one of those facets so I thought about cutting them before veneering, but the more I thought about it, I concluded that I had to veneer first since each of those facets has a different bevel on each side. That means that some of the points on those triangles are like needles with practically nothing behind them. I thank you for your kind words as it was in spite of the difficulty, a fun and challenging build. Here's another picture for you to enjoy.
delwon
« Reply #31 on: 5 Feb 2014, 01:15 am »
Just noticed the typo in my post. The veneer is mappa burl.
jtwrace
    • TIPP YouTube Channel
« Reply #32 on: 5 Feb 2014, 03:20 am »
Any way to hear these in NC?
Rick Craig
  • Selah Audio
« Reply #33 on: 5 Feb 2014, 06:34 pm »
This pair will be in the Philadelphia area.
jtwrace
« Reply #34 on: 5 Feb 2014, 06:50 pm »
Guess this is a no.  Thanks anyway.
diofan56
« Reply #35 on: 23 Feb 2014, 07:23 pm »
Wow!  Those are some funky-looking cabinets!
