High Sensitivity 3-way
0 Members and 1 Guest are viewing this topic. Read 15167 times.
Rick Craig
  • Selah Audio
    • http://www.selahaudio.com
« on: 5 Apr 2013, 04:28 pm »
This project will be starting soon with Acoustic Elegance and RAAL drivers. I'll post when I have an update.  :thumb:
R_burke
Re: High Sensitivity 3-way
« Reply #1 on: 5 Apr 2013, 04:54 pm »
Shame on you  :nono:  You have to give us some hints >90, >95...
studiotech
« Reply #2 on: 5 Apr 2013, 08:42 pm »
Can't wait to see it!  TD6M?
Greg
nickd
« Reply #3 on: 5 Apr 2013, 09:16 pm »
Not even a sketch Rick?
 Sheesh.
Rick Craig
  • Selah Audio
« Reply #4 on: 5 Apr 2013, 11:07 pm »
Probably in the 95db range but I'll know more once I test the drivers.
Rick Craig
  • Selah Audio
« Reply #5 on: 6 Apr 2013, 02:16 am »
Greg
Yes, the TD6M.
Rick Craig
  • Selah Audio
« Reply #6 on: 6 Apr 2013, 02:42 am »
 Sheesh.
This is a custom kit design so I won't have any cabinet pictures until my customer provides them. His cabinets will be a large floorstander but it also is possible to make it a 2-pc. cabinet with a woofer module forming a base for a midrange / tweeter cabinet.
bernardo
« Reply #7 on: 8 Apr 2013, 04:12 pm »
Rick-
Sounds like from your last post you are providing drivers and support for someone's project. I assume that these won't be available for an audition.
Rick Craig
  • Selah Audio
« Reply #8 on: 8 Apr 2013, 04:47 pm »
Rick-
I will have just one for audition since all testing will be done in mono.
Shogun
« Reply #9 on: 26 Jun 2013, 02:54 pm »
Please update
Rick Craig
  • Selah Audio
« Reply #10 on: 26 Jun 2013, 05:00 pm »
Please update
The cabinets (complex faceted fronts and some other tapering) are being built by Del Won so I won't have any pictures for awhile. If you have any other questions pertaining to the design please feel free to ask.
ttan98
« Reply #11 on: 26 Jun 2013, 10:58 pm »
Hi,
What is the estimated price for a pair of speakers incl. drivers and cross-overs?
Michael Anderson
« Reply #12 on: 27 Jun 2013, 02:06 am »
Hello Rick, I too would be interested in any more details of these speakers that you could provide . Actual drivers used etc.
Thanks Mike
Rick Craig
  • Selah Audio
« Reply #13 on: 27 Jun 2013, 02:43 pm »
Hi,
This isn't a kit that I'll be sellling since the woofer and midrange drivers can be purchased directly from Acoustic Elegance.
Rick Craig
  • Selah Audio
« Reply #14 on: 28 Jun 2013, 03:15 pm »
Thanks Mike
Acoustic Elegance 15" and 6.5" mid plus a RAAL 140-15D. We looked at the cabinet size / tuning for a ported box and in order to get a flat response the volume was very large. The sealed box is much smaller and measures very well plus we can add EQ from the MiniDSP as desired to further extend the bass.
guest44244
  • Guest
« Reply #15 on: 29 Jun 2013, 12:40 am »
which TD15 are you using ? one per cabinet ? sealed ?
donc
Rick Craig
  • Selah Audio
« Reply #16 on: 2 Jul 2013, 07:25 pm »
donc
One TD15M per cabinet and sealed.
studiotech
« Reply #17 on: 3 Jul 2013, 04:03 am »
Even with DSP, I have to imagine a subwoofer will be augmenting output below 40-50Hz, yes?
Pete Schumacher
  • It's all in the pursuit
    • Vapor Audio
« Reply #18 on: 3 Jul 2013, 04:40 am »
Probably not necessary in a normal listening room.  With DSP, that 15" woofer will have in-room extension into the 20s with ease.
Rick Craig
  • Selah Audio
« Reply #19 on: 4 Jul 2013, 02:06 am »
No subwoofer since the extension can be tailored with the DSP.
