Bugle power supply question
0 Members and 1 Guest are viewing this topic. Read 1654 times.
russe41
« on: 7 Jul 2004, 09:02 pm »
I'm using power one brand  dc +or- 15v supplies @1 amp,one for each channel in a seperate pwr supply case.
How should these be wired into the bugle ckt board since I ommitted the
on off switch,c7,c10,c8 and c11?
Thanks for any advice!
hagtech
« Reply #1 on: 8 Jul 2004, 07:31 am »
Just wire the supplies into B1 and B2 locations.  B2 is negative side.
jh :)
russe41
« Reply #2 on: 8 Jul 2004, 09:32 pm »
I'm not using a switch on the board,it will be switched on from another seperate box hooked together with an umbilical cord.can it be hooked to the left of where B1 and B2 go into S1?
hagtech
« Reply #3 on: 9 Jul 2004, 06:30 am »
Yes, you can wire straight to the switch location.  I prefer to jumper across the switch because then you can add electrolytic caps to the supply rail (next to battery connectors).
jh :)
