Corning 705 1"
0 Members and 1 Guest are viewing this topic. Read 1267 times.
DTB300
Corning 705 1"
« on: 3 Apr 2013, 01:55 pm »
I do know this is Rigid Fiberglass....but can it be bent or curved slightly???  I do not have any to try out, so I thought I would asked the group here.    Or will it break apart like EPS?
bpape
    • Sensible Sound Solutions
Re: Corning 705 1"
« Reply #1 on: 3 Apr 2013, 02:16 pm »
You can bend it slightly - not a lot though.  Might have better luck with 703 bending a bit more. Whatcha tryin' to do?
Bryan
DTB300
Re: Corning 705 1"
« Reply #2 on: 3 Apr 2013, 03:05 pm »
Put behind a slightly curved panel.    Tried to find a good example of the curve, as I do not have a picture with me.  I would say the curve is similar to the RPG BAD curve but bigger.
So the 703 with lower density will bend easier than the higher density 705
bpape
Re: Corning 705 1"
« Reply #3 on: 3 Apr 2013, 03:24 pm »
Yes. Like I said, all depends on how much you need to bend it.
