FS: Emotiva LPA-1
0 Members and 1 Guest are viewing this topic. Read 1238 times.
jephdood
FS: Emotiva LPA-1
« on: 3 Apr 2013, 03:20 am »
Great shape. Works perfectly. Was given a deal on a Parasound I couldn't pass up, so selling the Emo.
If you don't know the specs:
Rated Power Output: (All Channels Driven @ 1Khz, 120VAC/ 60HZ supply, THD noted)
Channels 1-5 125 Watts into 8 Ohms (0.04%THD)
225 Watts into 4 Ohms (0.04%THD)
Channels 6-7 50 Watts into 8 Ohms (0.05%THD)
95 Watts into 4 Ohms (0.05%THD)
Frequency Response:
20-20Khz: +/-0.1dB
10-100Khz: +/-1.0dB
Total Harmonic Distortion (THD): (80kHz measurement bandwidth)
Channels 1-5: <0.040%
Channels 6-7: <0.052%
Signal-to-Noise Ratio: >100dB, Unweighted (Full Output Reference)
DC Offset: <1mV
Crosstalk: >75dB
Damping Factor: Approximately 200 into 8 Ohms
Input Sensitivity Range (Gain):
Channels 1-5 29dB
Channels 6-7 26dB
Input Impedance (RCA Input) 47K Ohm
External Trigger Input: 3-12 VDC, center tip of 3.5mm jack is positive
Clearance for ventilation (Back): Minimum 2” / 50 mm
Electrical Power Requirement: 1200 watts @ 115VAC when driven into 8 Ohms
Electrical Power Consumption: 4 Watts (Standby) and 46 Watts (Idle)
Raw Weight: 63lbs / 28.63kg
Shipping Weight: 70bs / 31.81kg
Dimensions: 17” W x 7.75” H x 19” D
432mm W x 197mm H x 483mm D
I need to net $450 for the amp. So, for local buyers, that's $450 cash. For everyone else, that's $450+pp+shipping/insurance.
I have the original box and packing. Any other questions, go ahead and shoot them my way.
Thanks.
jephdood
Re: FS: Emotiva LPA-1
« Reply #1 on: 12 Apr 2013, 03:45 am »
Bump!
