Rythmik 370PEQ amp and GR SW 12
0 Members and 1 Guest are viewing this topic. Read 1289 times.
Manolo
  • Consulting Structural Engineer
« on: 2 Apr 2013, 08:53 pm »
Two questions:
Can I use that plate amplifier in a SW with a non Rythmik woofer?
and, could i use only one GR SW-12-16FR in an open baffle?
Danny Richie
Re: Rythmik 370PEQ amp and GR SW 12
« Reply #1 on: 2 Apr 2013, 08:57 pm »
You can use the A370 on a non-servo woofer if you have Brian take the servo board off of the amp.
And you can use one woofer in an open baffle with the A370 amp but output will be limited. The amp will output a max of about 125 watts of power into the 16 ohm load.
