0 Members and 1 Guest are viewing this topic. Read 10960 times.
They are now in Blackmore's house, making sweet tunes. 2 weeks and off to the first out of town stop.
They have landed in Minnie, just beating the impending snowmageddon. Here's a crappy picture of them in the room.System at the moment is Ghent IcePower amp, Slagle Autoformer volume and Tjoeb Ah! CD player. Will bring out my F5 monoblocks for a try in a few days.Could the box be any heavier?!
the tjoeb ah cd player scares me - is it really up to snuff in 2013? - i hope this review isnt tainted by ah tjoeb
C'mon... Tainted review? It is a CD player that the reviewer likes, and well within the price points of a likely purchaser of the Breeze. We will get impressions of what the Breeze can do with some interesting amplification (looking forward to your impressions of the F5s with these, BTW), and likely get comparisons to other speakers with the same front end combos (assuming other speakers on hand are suited to the F5s). Can we please not put down other ACers gear? We chooses what we likes and what we can afford. You will be able to give your impressions based on the gear you have chosen for your system in due time.
Not dissin other peoples equipment - but if that is the only source for music and it was all the rave from 2000 - 2005 - then i think it is crucial to the outcome unless the cd player was upgraded within the last 2-3 yearshow would you feel if i told you that im using an (realistic amp from radio shack circa 1975 and a marantz cd player circa 1987) - i think reviews should only be done with equip that is sort of up to date - at least within the last 2-3 years for a cd player and longer for a turntable
Wow, really glad I don't live on a planet where if my gear is over 3 years old it doesn't sound good anymore. That would be rough, and expensive. Every time I finished updating my system I would have to start over again.
Not to worry. I'm absolutely confident that no matter what source gear is used, be it music server, CD, or turntable, that the Breeze will deliver sound that will astonish the listener and make them think that they've upgraded every component in their system.
I'm starting to become a little concerned now that my cd player may be almost 8 years old now . (bought it used so I'm really not sure though) I hope you're only refering to older sources as there's alot of fine vintage amps out there
