sold
0 Members and 1 Guest are viewing this topic. Read 3701 times.
ericjan93
sold
« on: 1 Apr 2013, 02:59 am »
Monarchy SE100 Delux Mark 2 Mono pair in like new condition. Original one owner. Hand pick direct from Monarchy Audio sound room last year. This pair is current 2012 production. This is SM70-Pro's big brother with more power. The are sold for 1179 ea. new. I'm looking into tube integrated amps, so I'm letting these go.
Aso selling Monarchy audio tube preamp
http://www.audiocircle.com/index.php?topic=115542.0
will sell it as a package for $1700 with the monoblocks and preamp.
One of the best setup you can get for this kind of price.
Audioreview 5 out of 5 stars.
Soundstage (Wes Philips): "The Monarchy SE-100 Delux Monoblocks are superb amplifiers. They are well built and offer highend sound that is sweetly detailed and authoritative".
Stereotimes (Frank Alles): "For those of you who may be looking for a solid state amplifier, that sounds as good or better than many revered push-pull tube amplifiers, your search could be over. Without hesitation I can recommend the SE100 delux mark 2 amplifiers to those who require moderately high power that sounds as smooth and sweet as music itself".
Lps on top just to show scale, not included in sale, although I did use the SE-100s to play both records with admiring results: seductive on the first one and showcase powerful on the other.
SE-100 MK 2 improvements
•   current mirror input for more stable output throughout entire dynamic range
•   improved current source at both input and driver stages: far lower distortion and higher operating speeds
•   sophisticated output MOSFET pairing and protection: higher current output: will handle 2-ohm loads
•   Dual low noise bridge rectifiers: even better than soft-recovery diodes will better meet current demands during high dynamics
•   cascaded driver tightly preserves signal integrity: excellent sound staging
•   time-delay relay eliminates turn-on thump
•   positive over-drive protection with very clean clipping
•   improved layout and wiring techniques result in hum free operation
FTC Output Power:
100 Watts RMS on 8 Ohms (Both Basic and Delux versions)
200 Watts RMS on 4 Ohms(Delux version)
160 Watts RMS on 4 Ohms(Basic version)
Frequency Response:
-0.1 dB from 20Hz to 20KHz at 1 Watt
Signal-to-Noise Ratio: Greater than 120 dB below rated FTC Full Bandwidth Power
Slew Rate: 50V microsecond
Input Impedence: 40 K Ohm
Damping Factor: Better than 600 from 10Hz to 400Hz
Voltage Gain: 26 dB.
Dimension: W9”x H5” x D12”, Net Weight 22 Lbs, Gross Weight: 25 Lb
Accept paypal.
« Last Edit: 7 Jul 2013, 08:15 pm by ericjan93 »
ericjan93
bump
ericjan93
priced to sell asap, need money for an integrated amp
mtanielu
Hi,
I have a melody I2A3 integrated if you would like to consider a trade plus cash.
mtanielu
Still available?
ericjan93
Still available?
yes it's still available!
I was out of town for a month, didn't have time to check the posts, sorry!
ericjan93
bump
edmondwolfman
Do these amps run cool enough to be in a cabinet with a glass front but with slots in the back? In my rig they would have to be in a cabinet. And also how wide are they? I see you have 9 in. listed above but I read some specs somewhere that said the MK 2s are 11 in. wide.
« Last Edit: 26 May 2013, 12:17 am by edmondwolfman »
ericjan93
bump, please call or txt me @ 4085685373 if you are interested, I don't always see the messages on time!
-Eric
boniccie
Still available? Thanks Dan
ericjan93
sold, sorry!
