Bryston expert needed
0 Members and 1 Guest are viewing this topic. Read 2030 times.
budt
« on: 27 Mar 2013, 03:50 pm »
  Can anyone here tell me what pin is HOT in regards to the balanced inputs/otputs on a BP26 preamp? Also on the 7b sst2?
  • The Demo is Everything!
    • http://www.bryston.com
Re: Bryston expert needed
« Reply #1 on: 27 Mar 2013, 03:57 pm »
Pin 1 is Ground - Pin 2 is Hot - Pin 3 is Neutral
james
brucek
« Reply #2 on: 27 Mar 2013, 03:57 pm »
Pin 1 = Ground/Shield
Pin 2 = Hot (+ve)
Pin 3 = Cold (-ve)
brucek
budt
« Reply #3 on: 27 Mar 2013, 03:58 pm »
   Thanks for the quick response.   Now I can configure my new Esoteric K-03 properly and decide if I like balanced or unbalanced.
Speedskater
  • Kevin
« Reply #4 on: 27 Mar 2013, 04:17 pm »
If it's a XLR balanced cable, then:
Pin 1 is Shield & Chassis but not Audio Ground.
Pin 2 is signal Plus.
Pin 3 is signal Minus.
mkaiser
« Reply #5 on: 28 Mar 2013, 02:20 am »
There you go Budt, 3 answers to your 1 question.  :oops:
