My First Hypex Project - UCD 180ST
0 Members and 1 Guest are viewing this topic. Read 3328 times.
tnargs
« on: 27 Mar 2013, 02:31 am »
My first UCD order has just arrived and I am pretty excited! 2x UCD180ST and 1x SMPS400.
My plan is to break all the audiophiles rules  :icon_twisted: and still hopefully have a really good amp!  :o
Basically I am making every choice that an audiophile would wish to avoid:
  • class D full range amp instead of A or AB
  • UcD instead of ncore
  • standard grade 180ST modules instead of high grade 180HG
  • switchmode power supply instead of linear
  • stereo instead of dual mono
  • no shield or separation of SMPS from UcD's
  • 'breadboard' flat Al base instead of a closed case, despite SMPS
  • standard cabling not exotic
I still expect to finish with a very good amp because I have a lot of faith in Bruno P.
I don't reckon there is a 'bad egg' in his basket, all his stuff is well engineered and executed
including the SMPS.
I plan to cart the tiny, scrappy, mini-muscle thing around my audio friends and see if they
think it sounds any better than expectations.
What am I thinking??  :duh:   We shall see.
Wish me luck!
Regnad
Re: My First Hypex Project - UCD 180ST
« Reply #1 on: 27 Mar 2013, 03:35 am »
Good luck!
Julf
  • Grumpy second cousin of Mark V Shaney
« Reply #2 on: 27 Mar 2013, 09:08 am »
I definitely wish you a lot of luck - and I take the opportunity to make a prediction. I am guessing that your amp will do great in proper double-blind listening tests, and really badly in sighted tests. :)
tnargs
« Reply #3 on: 27 Mar 2013, 09:20 am »
That's a great prediction Julf! I wouldn't bet against you.
Maybe I should set it to a gain of 1 and put it between their pre and power amps -- see if they can tell if it is switched (pun) in or out?   :scratch:
WJT4
« Reply #4 on: 6 Apr 2013, 05:28 pm »
Let us know how it works out.
I have an eight year old UcD-180 integrated from Hawk Audio in Belgium that's beat out every inexpensive amp I've compared it with.
