FS: SAS -7A preamp (SOLD)
0 Members and 1 Guest are viewing this topic. Read 1422 times.
Whitese
« on: 27 Mar 2013, 02:25 am »
I just bought this not long ago from here, but I have found an Aloia preamp to match my Aloia amp, so this great sounding linestage must go.
600.00 including shipping.
 Ships from zip 07047
SAS 7a with two upgrades: Jena labs wiring throughout and a HT bypass switch as well.
Black body with silver knobs as well as the three position "frequency profile" switch on the back and a switch for changing the power polarity. It uses a single E88CC/6DJ8/6922 tube... modern production tube and one Amperex Bugle Boy.
« Last Edit: 1 Apr 2013, 08:30 pm by Whitese »
Whitese
Re: FS: SAS -7A preamp
« Reply #1 on: 27 Mar 2013, 10:14 pm »
More info:
Premium model uses sealed selector switch and sealed balance/volume controls, and Jenalabs cryod wire in the signal path.
DC regulated filament power supply
Tube dampers
Extremely low distortion, typically .015% or -74db down total harmonic distortion, without any global feedback.
Its a great sounding preamp...but I have an Aloia preamp to match its amp coming soon, so bye bye.
Specs:
A robust 4 stage power supply provides better isolation from hash and interference from/through the rectifiers, transformer and AC line, for a cleaner, more open sound.
Power Line (AC) power reversal. One can choose the better sounding position.
Specs:
Frequency Response: 10 - 25 khz (+0, less than -.1db, 100pf, 100k load)
Gain: 19db gain, approx.
Total Harmonic Distortion at 2 vrms: 0.015% or less. (typically 74 db down, No global feedback)
Signal Polarity: Inverts
Input Impedance: 25k ohms
Min. Amplifier Input Impedance: 20k recommended
Tape Loops/HT bypass
Line Inputs: 5
Preamp.Outputs: 2
Dimensions: 17 3/4" wide
19" black rack front
4" high
11" deep
Actual Weight: 14 lbs.
Whitese
Re: FS: SAS -7A preamp Sold
« Reply #2 on: 1 Apr 2013, 08:30 pm »
sold
