Bassbox 6 pro
0 Members and 1 Guest are viewing this topic. Read 1341 times.
kinku
Bassbox 6 pro
« on: 26 Mar 2013, 06:23 pm »
Any one used this software for speaker design? Like to get some feed back as I am planning on buying a software to design a bass reflex enclosure.
WireNut
Re: Bassbox 6 pro
« Reply #1 on: 27 Mar 2013, 02:59 pm »
Yes. I've owned and used it for years. It's worth the $200.00 price IMO. Seems like it should be up to version 10 after all these years.
Easy to use, Lots of features at that price point. Driver updates are available on their web site. One thing I really like is after you make a design you can duplicate that design and have both on the screen at the same time, make changes to one of them, then run the grafts for both designs at the same time and see how changes from one cabinet to the other effect the sound. Also the push-pull feature worked great for me. For $200 I like it.
kinku
Re: Bassbox 6 pro
« Reply #2 on: 27 Mar 2013, 03:17 pm »
How good is it with designs.Did you get good results from boxes constructed using Bassbox?
WireNut
Re: Bassbox 6 pro
« Reply #3 on: 27 Mar 2013, 03:27 pm »
My current loudspeakers where built long before I had bassbox. I'm still working on the second push-pull cabinet and hope to have them finished this spring. As far as the push-pull features goes it worked great and was extremely helpful. I couldn't have done it without the software. I've used other freeware software but have always come back to bassbox due to it's ease of use and features. I'd buy it again if I was looking.
