Just learned how to make correct 'squared' sign so 4B-SST2 can be 4B-SST²
0 Members and 1 Guest are viewing this topic. Read 2039 times.
Elizabeth
The standard windows/ Microsoft the squared sign can be made using the keypad (not numbers above letters) press 'alt'and key in 253 at same time. When you let go the 'squared' proper symbol will be in place.
Cool.
I hated always typing in 4B-SST2 instead of 4B-SST²
Speedskater
  • Kevin
With some firmware it may require:  [alt]0253 rather than [alt]253
  • The Demo is Everything!
    • http://www.bryston.com
Cool.
Nice tip - thanks  :thumb: - I have been struggling with that myself :duh:
james
Speedskater
  • Kevin
more:
 © [alt]0169
 ® [alt]0174
 ¯  [alt]0175
 °  [alt]0176
 ± [alt]0177
 ²  [alt]0178
 ³  [alt]0179
 ´  [alt]0180
 µ  [alt]0181
 º  [alt]0186
 ¼ [alt]0188
 ½ [alt]0189
 ¾ [alt]0190
 ²  [alt]253
 ý  [alt]0253
Speedskater
  • Kevin
Notice that these sometimes work different ways. There are hundreds of characters.
Do a search on:
ANSI Character Set
Windows Character Set
Napalm
Cool.
And now your amp sounds better too. More definition and air.
Chicago
4Bsst² accomplished in MAC.  You can get there by going to Edit and then selecting "special characters".  You may need to click on the gear in upper left of window and then go to "digital - all" to find the ².  You will find it under "superscript 2".  I can't believe what entertains us.
yioryos
œ∑´®†¥¥¨ˆøøˆˆ¨æ…≤µ˚∆¬˜∆˙∫√©∫˙©√∫∫˙˙˙∆˜å
