Scatter Plot Woes
0 Members and 1 Guest are viewing this topic. Read 1043 times.
Doublej
Scatter Plot Woes
« on: 26 Mar 2013, 01:03 am »
I need to create a simple scatter plot chart for work. 25 data points. x values range from 1-10, y values range from 1-10. label each point.
Seems simple, no? Should take all of two minutes in Excel. The problem is you can't label data points in Excel without writing a complicated freaking macro. Are you serious?
Anyone got a simple solution?
Maritan
Re: Scatter Plot Woes
« Reply #1 on: 26 Mar 2013, 02:39 am »
This is probably just as time consuming as writing a macro, but how about making each x-y point a separate series? Plot it, and using the built in option to display series name?
skunark
« Reply #2 on: 26 Mar 2013, 04:08 am »
Might see what OpenOffice can do or GNUPlot.
