Single servo sub H-Frame
0 Members and 1 Guest are viewing this topic. Read 1539 times.
AKLegal
« on: 25 Mar 2013, 08:05 pm »
Has anyone tried using a single servo sub in a H-frame?  I know the dual configuration found in the Super Vs has some benefits.  Would it be worth it to try this?  I see alot of single H frame subs in the OB section of AudioCircle.  I'd like to build a stereo pair of single H-frames and then maybe put a single sealed servo at the rear of my room out of phase with the OB subs.
Danny Richie
Re: Single servo sub H-Frame
« Reply #1 on: 26 Mar 2013, 01:29 am »
Mine were designed to be used in pairs or in threes. Using just one single 16 ohm woofer on an amp designed to drive 4 ohm loads is not getting the most out of the amp.
