0 Members and 1 Guest are viewing this topic. Read 7984 times.
Great software and very useful too. :thumb:thank you Dan. I guess without baffle compensation all speakers can have a midband peak.Is it the reason people complain about some full range speakers?using them without a baffle compensation?In between something confusing reading the instructions"The Edge suggests two different compensation circuits, circuit 1 is suited for passive realization in the crossover, in this case the driver should be connected in series with L and R2 in parallel."Does that means Land R2 are parallel and both connected in series to speaker?It is also interesting to see that the peak is lowest when speaker is centered little bit off from the center along the width too?Is it for real!!!
MJK total investment for getting the software simulation from you is reasonable but the platform to run it is expensive.
I try to play around with sample MATHCAD file at MJK site. First on explorer that opened up a file like pdf ...I am expecting to get a feel before I use it since I have to purchase the worksheet file.
...It does not seems like a typical software application where you provide data in the input fields.
I am not sure there is dedicated worksheet for bass reflex system with MJK,he mentioned some TL_ML worksheet.I looked through the listing could not find one....Is it not transmission line speakers are different from bass reflex model?Especially of small dimensions of 6-10 litters.
