0 Members and 1 Guest are viewing this topic. Read 19198 times.
Zybar,Have you made a decision? Have you found good prices on line for either DCX2496 or the Driverack PA?I'm in a similar situation.Thanks,Al
Somehow I was thinking this was used between the digital source and preamp, but it looks like it takes an analog signal from the preamp and then converts to digital, does its business and converts back to analog with multi outputs. Wonder if you can find one that inputs digital to skip one unnecessary conversion.
Zybar,That is how I use the DriveRack. I considered not using any passive crossovers but after talking with Rick Craig I thought it best to use a passive crossover in the array.I think I made the right choice* If the digital crossover power cycles on you without a passive crossover to protect ribbons it could get real ugly. You will hear a loud pop. The Xover has to be on first then your amps.Sudden power loss without some tweeter protection could make for a bad day.
Zybar,I think I made the right choice* If the digital crossover power cycles on you without a passive crossover to protect ribbons it could get real ugly. You will hear a loud pop. The Xover has to be on first then your amps.Sudden power loss without some tweeter protection could make for a bad day.
